trying to re-install rear seats
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
I want to keep most of the roll cage that was in my car, but I need to cut out a couple of cross braces in the back seat area to put the back seat back in to get ready for the Power Tour. Don't worry, I do not plan to race the car, it makes the chassis feel solid as a rock. My question is how is the bottom seat hels in? I see how the bench bolts in, but how does the bottom stay in? A couple of close up pics of how the seat mounts would be great, also. Thanks.
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Well my 92 Z28 just has a single bolt in the middle of the seat bottoms (in the front bottom middle part of the seat) and they attach to the floor. I think they are all the same.
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
r rollcages not allowed on the powertour? cause i know ur not gonna try to put 4 people in there.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
f**k the power tour, do not remove a rolcage from a car. they are the coolest things ever.
Car: 1991 Z28 1LE
Engine: LB9
I am not removing the cage. I just want to notch out a couple of the inner braces that block the rear seat area. I have to get a carseat in there for my 14 month old! They say "take a kid to a car show", well what better way to do it than on the Hot Rod Power Tour!
I will get some pics of how the cage goes threw the dash shortly.
Car: 1991 Z28 1LE
Engine: LB9
Here is a couple of the dash. Please excuse the dirty carpet. I will try to get a couple of better ones if you need it. Feel free to email me if you need them.
Engine: 2.8L, LS1
does the AC still function? just wouldn't want to be a 14mo old in a hot thirdgen in the summer.
Car: 1991 Z28 1LE
Engine: LB9
1LE has the A/C delete. I am having a Vintage Air A/C unit installed.
With a little hot rod engineering, I think I can make it work.
Car: 92 Camaro z28
Engine: 427 sb
Transmission: th400
Axle/Gears: 9"/4.30
Thanks for the pics. I'm getting ready to install my cage. Hopefully, I'll have it installed in time for the power tour. Is that a chassis engineering cage? Ronnie
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
cage looks really sweet. i would cut the seats and re do them or make up something else before i would cut the cage.
Car: 1991 Z28 1LE
Engine: LB9
Thanks for the compliments on the cage. I wish I knew who to give credit to, the cage was done before I bought the car. Who ever did it was an artist. It looks even better in person. The welding to the chassis is outstanding. I am about half way done putting the baby seat in the back. I will post pics when completed.
1992 Trans Am
May 10, 2023 07:19 PM
