Help with new door handle install
Old May 17, 2005 | 05:43 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I went to install my new exterior door handles yesterday and they want to hit the body when you lift up the handle.
These are aftermarket handles and I have tried two different ones, with the same result. Any help would be appreciated! I need to get this car done!
Here's where it's hitting..
Old May 17, 2005 | 08:19 AM
BlackMagic's Avatar
Car: 1986 Firebird
i have not done any handel swaps yet, actually wanting to get rid of them period, but the handels look high. if there is a way to lower them then that might fix your problem
Old May 17, 2005 | 08:39 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
That's not my picture. But I know what you're trying to say. That is also part of the problem, the way the handle is sitting. I just wanted to see if anyone else had this problem; it might just be these aftermarket handles.
Old May 17, 2005 | 10:46 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
where did you get the handles. i got a pair from someone on ebay, i'm assuming they are aftermarket. when i replaced the driver's side, it seems to just barely hit. i didn't really mind though, since the paint job is crap right now and it's worn out behind the handle from the old handle anyway. the only thing i can think of is put a little shim behind it on top. that should pull it away from the door enough, but i don't think it will be noticable.
Old May 17, 2005 | 10:48 AM
Diabolical's Avatar
Engine: 305HO L69
btw, i totally forgot to take those pictures of the seatbelts for you. if you still want them, i will snap some tomorrow night.
Old May 17, 2005 | 05:06 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
did you use anything behind them when you install them? i used a stip of seam sealer from 3m it a long stringy rubber stuff. i just place a quick couple turns around the screw post and then install. that allows some extra space and will prevent rattles.
jeff
Old May 17, 2005 | 08:34 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I think that it could be the handles.....for me, it only did that when the OEM jandles were not tightened all the way though. Perhaps you should try some Junk Yard OEM handles?
Old May 17, 2005 | 10:29 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I ordered some GM handles from the dealer today and will get them tomorrow. I'll try putting some seem sealer behind the handles too. Thanks guys.
Old May 21, 2005 | 11:56 PM
josh formula 89's Avatar
Car: pontiac firebird
i had that problem with new oem handles the problem was they werent in the right position try moving them to the right or left and seewhat happens
Old May 22, 2005 | 12:06 AM
Metalhead's Avatar
Car: 89 Trans AM GTA, 99 Olds Alero GLS
Engine: TPI 350 L98
Axle/Gears: Borg Warner 3.27
This may sound dumb, but I think it would work (and look fine)... just grind some of the back of the handle off. I am planning on grinding down the front of mine to get rid of the lip around the edge so it will be flat before I get mine repainted.
Old May 22, 2005 | 01:30 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
The GM handles fit excellent. Much better than the aftermarket ones.
I probably could have grinded down the part that was hitting and it would have been fine. I just feel much better about OEM parts.
Old May 22, 2005 | 04:09 PM
stiers's Avatar
How much did the GM handles cost?
Old May 22, 2005 | 04:35 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
They were a little over $70 for the pair.
Old Aug 12, 2005 | 12:02 AM
polishdevil's Avatar
Car: 88 GTA
HELP GUYS!!! i just repainted my car and i can't get the stock handles to work now...i got them bolted to the car, tried the 3 different settings and for me to get the rod in the handle, i have to lift the handle a little and then i don't have enough leverage to open the door?!?!? WTF
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
