Headliner replacement
Old May 22, 2005 | 10:12 AM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I recently bought a new headliner material for my hard top iroc.
What type of adhesive should I use to adhere the foam backing to the cardboard for the headliner?
Old May 22, 2005 | 10:30 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Just goto your autoparts store and get some 3M spray adheasive. Make sure that you get all of the old material off of your old headliner. If there is any residue or old dried up foam or glue it will not stick.
Old May 22, 2005 | 11:15 AM
TKO500's Avatar
How about that super 77 spray adhesive? Anyone ever try that?
Old May 22, 2005 | 11:31 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have it and I can't remember if its for headliners or not. I have some 3M stuff not made for headliners and it isn't made to dry hard, it stays tacky all the time. It WILL NOT work for headliners. Get stuff specially made for headliners, you won't regret it.
Old May 22, 2005 | 11:35 AM
TKO500's Avatar
Sounds good to me. Everyone's input is incouraged and greatly appreciated!!!
Old May 23, 2005 | 02:05 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
I stress this procedure over and over. You may be lazy and be like "oh it will stick" or you'll see a little bit of material and be like "oh well, I got most of it off". DON'T DO THIS!. MAKE SURE YOU GET ALL OF THE OLD MATERIAL OFF. Otherwise you will be taking it back off again in 2 weeks. Either that or you will see that a little part of it is sagging... no big deal... right?
Wrong. A sagging headliner spreads like cancer. Pretty soon that little spot will turn into half of it sagging again. Don't make the mistakes I did. Take your time and do it right first. Due to my mistakes, my headliner is now being held up temporarily with staples because I am too lazy to rip the headliner out again.
Old May 23, 2005 | 01:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I thought super 77 was meant for headliners.. Or it's commonly used...
Any other brands/styles to consider?
Old May 23, 2005 | 04:38 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Do not use Super 77 use the 3M for upholstery Or any other glue made for upholstery.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
