camcorder bracket??
Old May 24, 2005 | 12:44 AM
cross_fire3's Avatar
Car: 83 camaro z28 cross_fire
camcorder bracket??
hey has anyone made a camcorder bracket to film straight through the windsheld for races or cruises or what ever?? thanks
Old May 24, 2005 | 02:21 AM
Kandied91z's Avatar
for a cage? you can buy them all day long... they aren't expensive. i have one for mine which was only $35
Old May 24, 2005 | 02:13 PM
i dont have a cage so i was jus wonderin if anyone made them into the seats or something
Old May 24, 2005 | 03:12 PM
Kandied91z's Avatar
ahh... yes that would be difficult then.
Old May 24, 2005 | 03:21 PM
TexasLT1's Avatar
Car: '92 RS
not so much. a little time consuming though if you want it to be decent.
cross_fire see my post in the fabrication section
Old May 24, 2005 | 03:37 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I made a sweet one for my dads old S4 in 15 min. It was a just a prototype. A simple wood board with two holes for the headrests post to go through. Then I used the mount off of a tripod on the other end.
camera seat posts
Old May 24, 2005 | 03:40 PM
Kandied91z's Avatar
yeah if you don't care about looks that would be a great way to go. you could always hide the board underneath the carpet as well. make the legs detachable from the board using plastic hardware you can find at lowes or home depot so that when you aren't using the camera it's all concealed. nothing short of easy but you could do it with some time and patience. wouldn't be too expensive either.
Old May 24, 2005 | 06:46 PM
i have a amp rack on my rear deck so ill probably try and figure a way to mount it on that some how
Old May 24, 2005 | 07:04 PM
theshmo891's Avatar
duct tape a camcorder between the 2 headrests , if you post pics of your amp rack, it would probably help...
Old May 24, 2005 | 08:10 PM
BadGirlIROC's Avatar
Car: 87 IROC-Z
Engine: 355 carb'd
We have one made for a small Sony cam! I'll get you a pic if you'd like. We don't have them listed on the site yet. Please PM me if interested.
Old May 24, 2005 | 08:33 PM
Originally posted by theshmo891
<a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=22&k=duct%20tape" onmouseover="window.status='duct tape'; return true;" onmouseout="window.status=''; return true;">duct tape</a> a camcorder between the 2 headrests , if you post pics of your amp rack, it would probably help...
i could try and mount it between the seat and the edge of the rack with a clamp or something...
Old May 24, 2005 | 09:17 PM
EvilCartman's Avatar
Car: '82 Z28
I use a thing called the StickyPod. 4 suction cups on an aluminum base with a couple of extentions. You can stick it to the windshield, side window or in my case the T-tops. I've also stuck it on the side of the car and went for a drive up a curvy road. Also used it on my 4x4 and it was on the side window for a good 3 hours driving through the snow.
Old May 24, 2005 | 09:19 PM
Car: 87 IROC-Z
Engine: 355 carb'd
The thing we have has suction cups that stick to the windshield and it holds the camcorder down in between these two X pieces. Works pretty good!
Old May 25, 2005 | 10:50 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Chase cam
Old May 25, 2005 | 10:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have t-tops, you could probably make an "L" style bracket that attaches to the t-bar.
here is a quick drawing I made,
Old May 25, 2005 | 11:20 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I dont kno about for long long video but this guy on here i kno has a nice camera that uses suction cups where ever he wants filmed, for instance. On the quarter panel filming the tires traction. On his back window outside the car. Its awsome. Thats would i would like cause it picks up all sounds etc
Old May 25, 2005 | 11:57 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
http://www.chasecam.com/cruisecam/index.html
That attaches to the headrest. It would be a great way to get footage.
Their main site also has some great stuff for collecting car footage, they sell bullet cams, and mounting options.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
