Will they fit?
Old Jun 2, 2005 | 10:21 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Will they fit?
Looking to C6 wheels on my third gen. Its a 1984 Z28. I have a 12 bolt strange rear end, with baer brakes. 12' in When I bought the rear end I told them Id be using a 17 in or taller wheel
will the 18's up front and 19's in the rear fit?? Also 10 inches wide in the rear and like 9 or so up front..could be wrong about the front wheels
here they are
http://www.completedreams.com/xcart/...cat=257&page=1
File Type: bmp
Old Jun 3, 2005 | 12:01 AM
Spdfrk1990's Avatar
I dunno why but this thread made me think of OJ with the name blackgloves and title will they fit??
Old Jun 3, 2005 | 01:35 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
LMAO
Old Jun 5, 2005 | 04:23 AM
Slinkoguy's Avatar
Car: 87 Formula 350 / 89 Firebird
Engine: L98 / 2.8 V6
Transmission: 700r4 / 700r4
Axle/Gears: 9 Bolt 3.27 / 10 Bolt 3.42
I had the exact same thought!
Old Jun 5, 2005 | 05:43 AM
Spdfrk1990's Avatar
To answer your question you will need adapters.
Old Jun 5, 2005 | 02:33 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
2" adaptors if i remember right...
Old Jun 5, 2005 | 03:49 PM
Slinkoguy's Avatar
I all depends on the offset of the rear. If it is a thirdgen offset you will need 4 2in adapters.
Old Jun 6, 2005 | 12:30 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The aftermarket seems to be selling 2 different versions of the C6 style wheels. One uses the OEM C6 wheel sizes and offsets - I added them to the wheel adapter FAQ at http://www.skulte.com/adapterfaq.html. The other uses C4/C5/4th gen offsets.
If you're going with the OEM C6 sizes, they are 18x8.5, 58mm fronts and 19x10, 79mm rears which require our 2" wheel adapters for the front, and 2.25" adapters for the rear. I hope this helps.
Old Jun 6, 2005 | 10:56 PM
Car: 1987 IROC-Z
Engine: 6.2L
Well Strange Engeneering asked me what size wheel I wanted to run, I told them 17 or larger. So they sent me a 12 bolt according.
I was more worried about them just fitting in the wheel wells. When I buy my wheels, Ill aske them about the adapters ect..
anyone know about them just fitting in the wheel wells??
Old Jun 6, 2005 | 11:06 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
19" should fit but your going to have to run a pretty small profile tire, smaller than i ever would on my car
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
