4th Gen Rear Seat
Old Jun 7, 2005 | 11:28 AM
lxcamaroxl's Avatar
Car: 92 Camaro (R)eally(S)tock
Engine: 305 TBI
Transmission: Auto 700r4
4th Gen Rear Seat
I need to know how to get the top part of the rear seat from the 1994 camaro, so i can put it in my 92. I have tried with an allen key but there is no space between the quater panel and the seat.
Old Jun 7, 2005 | 03:26 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Are you trying to remove the seat from the car?
If so, just reach down in to the lower sides of the seat and remove the 13mm bolt from each side then pull the seat up and out.
If you are trying to take off the seatbelt guide, lower the seat forward and get the correct size Torx bit and carefully remove it.
Old Jun 8, 2005 | 09:07 AM
lxcamaroxl's Avatar
Engine: 305 TBI
what tool do I use.
theres barely any space to loosen the bolt
Old Jun 8, 2005 | 09:57 AM
Zepher's Avatar
use a 13mm Wrench.
It sounds like you are trying to remove the bracket off of the car, you don't need to remove that, just the nut that holds the seat to the bracket since the brackets are the same on the 3rd gen and 4th gen.
Old Jun 8, 2005 | 11:18 AM
lxcamaroxl's Avatar
Engine: 305 TBI
Im wicked confused
sorry
Im trying to take off the bolts that are on the lower part and on the sides.
Old Jun 8, 2005 | 01:21 PM
lxcamaroxl's Avatar
Engine: 305 TBI
I was bored so i made a retarded picture to try and clear things up. i doubt it will.
Old Jun 8, 2005 | 03:25 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
get a 13 mm socket with extention. feel under the bottem parts of the seats in the front. theres 1 bolt per seat. take those out and then you can get to the bolts for the top section of the seats.
Old Jun 8, 2005 | 07:05 PM
Zepher's Avatar
Here is a pic of the right side (when looking to the back of the car), just use a wrench on it it and loosen the nut at the bottom, gear wrench makes it easier but all you have to do is loosen it and undo it with your fingers if it isn't rusty.
Old Jun 9, 2005 | 07:08 AM
lxcamaroxl's Avatar
Engine: 305 TBI
Oh man. Thanks . that clears it up soo much. I didnt see the bottom on. Its getting hot so that car doesnt get air much so everytime i go in its scorching hot, so i have limited time before i pass out.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MORREALE5
Sep 13, 2015 09:16 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
