fiberglass hood problem
Old Jun 8, 2005 | 10:44 PM
ws6jim's Avatar
Car: 1999 Firebird Formula
Transmission: Stalled 4l60e
No its not a question about alignment. The edges of my ASCD hood are cracking. My body shop says the hinges are strong for such a lightweight hood. Everytime I close I have to move the hood down before the back end follows. When I lift the hood it lifts off center and and hangs in the corner a bit. Will the 83 fiberglass hood struts solve my dilemna or do I have to search for a worn out set from the junkyard. Has anybody heard of or had this problem. When I talked to a Tech at ASCD he told me this rarely happens.
Old Jun 9, 2005 | 09:44 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Are you still using the stock steel hood struts? If so, you need to remove them asap. I would get a set of the one for the factory plastic hood.
Old Jun 9, 2005 | 11:50 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
same thing, yes it should solve the problem.
Old Jun 9, 2005 | 10:03 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
there was a stock plastic hood on our cars at one point?
Old Jun 9, 2005 | 10:30 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Never. 'Glass and Steel.
Old Jun 9, 2005 | 11:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Its actually plastic w/fiberglass.Same as fieros,vette.etc panels.Anyway you can adjust the Rr of the hood(sticking,hanging.etc).There is a small round rubber cap on the very back of the fender.just in front of the windshield.Remove the rubber cap.Rotate the bolt either up(if hood stick/hangs)or rotate down(if hood is too high when closed or pops up too soon when opening).That should help some,if your struts are already worn out some(if you can compress they are,some).They should be O.K to use.However if you CANT compress then try an other set.
Old Jun 10, 2005 | 07:49 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I say it depends upon which fiberglass hood you have. The one i have weighs as much as my factory hood. When i bought my hood over a year ago i bought brand new hood struts for my car and i have had 0 problems with it. I tried using the hood struts i had before but they wouldnt hold it hood up it was too heavy. I dont think those ones for the factory glass hood would hold my hood up.
Old Jun 10, 2005 | 07:59 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
also WD-40 the hindges
Old Jun 10, 2005 | 10:31 PM
DanTheMan_smlk's Avatar
hmmmm i have a 91 Z28 and my hood lifts off center also....im pretty sure its not fiberglass, its a stock hood. Should i do anything about it or will i be ok?
Old Jun 11, 2005 | 11:29 AM
Car: 1971 Camaro
Engine: 427
The hood appears to be fiberglass,
but in GM writings, they refer to the hood as 'plastic'
Old Jun 11, 2005 | 11:30 AM
Car: 1971 Camaro
Engine: 427
Never say Never.
Old Jun 15, 2005 | 01:36 PM
HELLO! anybody der?
Old Jun 15, 2005 | 02:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
actually, GM calls it SMC... for Sheet Molded Composite.
and if you dont believe me, go look in 82 camaro Z28 sales brochures, the FAQ and small sites online..... i used to have a 82 indy 500 pace car camaro.
Old Jun 15, 2005 | 02:25 PM
so theres a 100% chance i dont have a fiberglass hood... Where can i get just a stock looking fiberglass hood, i cant stand cowl hoods...can anyone help meh?
Old Jun 15, 2005 | 02:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by DanTheMan_smlk
so there's a 100% chance i dont have a fiberglass hood... Where can i get just a stock looking fiberglass hood, i cant stand cowl hoods...can anyone help meh?
VFN fiberglass makes stock RS hoods... they're identical to Z28s, but without the provisions for the louvers or power buldges..... however you can get aftermarket ones that fit onto it and make it look like stock..
since mines a RS and i dont care for cowls or louvers, im getting one..
Old Jun 17, 2005 | 01:07 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
You can get this 82-83 stock one on this link near the bottom of the page:
http://www.thirdgenusa.com/THIRD%20G...RTS%20PAGE.htm
Old Jun 17, 2005 | 02:45 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
3 of those available on ebay for $250 a piece... but must be picked up...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7945440276
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sweet_87_iroc
Mar 27, 2016 04:05 PM
Bert87
Aug 23, 2015 03:50 PM
