Blinker Return Spring PN needed
Old Jun 9, 2005 | 11:16 PM
CaysE's Avatar
Anyone have the part numbers to the left and right blinker return springs? Searches came up with nothing.
Old Jun 9, 2005 | 11:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
blinker return spring?You mean what makes the lever go back to off.If so i think its part of the signal light switch.Its sorta a flat type looking thing,like a mono leaf right?Junkyard time.
Old Jun 10, 2005 | 12:35 AM
CaysE's Avatar
No, they're springs in the steering column, somewhat L shaped with a spring loop at the corner of the L. Yes, they do make the blinker turn to off.
Old Jun 10, 2005 | 01:19 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I think those are in the signal switch though.I dont think there is a part #.You may have to swap the switch?
Old Jun 10, 2005 | 01:30 AM
CaysE's Avatar
They're not in the switch, they're in the column itself. I don't know the names of all the parts in there, but they sit in a round plastic piece that you can remove from the column. I've swapped them before but the ones I put in a while back are now going bad, so I wish to get new ones instead of used. If they come as part of a bigger PN, that's fine too, as long as I can get new pieces. I just need the PNs though.
Old Jun 10, 2005 | 01:43 AM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
You definitely do not have to swap the switch, as I replaced mine last week. I live across the road from a chevy dealership and just asked the parts guy for them. He brought out a box full of them, and I'm not sure they're even Camaro specific. The right side spring is red, the left is blue. I have a few spare sets as well (since they cost me $3 CDN/set) but there's no indication of a P/N since they're loose. I'd suggest simply going into a dealership and asking for them. If you have no luck, I can go ask across the road tomorrow and find out for you.
Old Jun 10, 2005 | 07:38 AM
CaysE's Avatar
If you have Paypal, I'll happily take a set off your hands.
Old Jun 10, 2005 | 10:03 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
these are the kinda things I wish i could understand why they go bad :P
your going thru your 2nd set of signal return springs now?? thats weird
mine feel pretty good im thinking im not going to see the day i have to replace the return springs, lets hope cos that would just be silly
Old Jun 10, 2005 | 10:46 AM
CaysE's Avatar
Yup second set. This car was not maintained at all prior to me buying it. Everything went bad on this car. Both return springs broke so I pulled them out of my old 84 Sport Coupe. Now one of those is broken.
I think I'll just go to a dealership around here. I noticed you're in Canada, RestoRoc89, and I don't plan on paying shipping for that. LOL
Old Jun 10, 2005 | 01:05 PM
RestoRoc89's Avatar
hehe, yeah, I figure it's probably not worth 20 bucks brokerage to get some springs. Your dealer should have them quite cheaply. It's a part the wears out with surprising frequency. Sometimes they just fall out into the steering column as well.
Old Jun 12, 2005 | 11:17 PM
SweetRide45's Avatar
The assembly is called a "Canceling Cam" and the springs are called "Preload Springs"...GM Universal...you can get 'em at any parts store in the HELP boxes
customblackbird
Aug 15, 2021 10:16 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
