Early Firebird 150mph speedo pics
Old Jun 13, 2005 | 10:04 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I wanted to upgrade the 85mph mechanical speedo in my 83 Firebird, but GM never made a 140mph mechanical speedo for thirdgen Firebirds (they had switched to electronic speedos by the time they made 140's). I could've used an electronic speedo and the box to convert it but I wanted to keep it simple.
GM kept the Camaro speedo mechanical until 1990. They had 145mph mechanical speedos available from 86-89. I thought I'd see if I could fit one in my Firebird cluster. It's an easy mod and you just have to cut one plastic post down to about half its size and the Camaro speedo drops right in.
Here's a pic of the stock 85mph speedo and 6K tach compared to the IROC 145mph speedo and T/A 8K tach.
Old Jun 13, 2005 | 10:08 PM
GarageToys's Avatar
The problem is that the gauge faces don't match each other perfectly. You also get the blue "brights on" light at the top of the speedo.
I hooked up with Scott from www.customgaugefaces.com and he custom made white faced overlays so everything matched. He even added a couple hash marks and made the 145mph speedo into a 150mph speedo. He put my yellow-lines and redlines on the tach where I wanted them, and he changed the tach reading from RPMx100 to RPMx1000 (so the numbers around the outside are just 1 2 3 4... instead of 10 20 30 40... I always thought that looked stupid).
Old Jun 13, 2005 | 10:24 PM
GarageToys's Avatar
The lettering style he uses closely matches the AutoMeter Phantom gauges- so when I put gauges in my pillar, they'll match the ones in the cluster.
BTW, thanks to ES87iroc -- He posted a pic of a T/A with an Iroc speedo in it many months ago and I just copied the idea and upgraded it by getting custom faces made.
Old Jun 13, 2005 | 10:53 PM
Slinkoguy's Avatar
Car: 87 Formula 350 / 89 Firebird
Engine: L98 / 2.8 V6
Transmission: 700r4 / 700r4
Axle/Gears: 9 Bolt 3.27 / 10 Bolt 3.42
Awesome work! Very nice cluster for a very nice car. I love it.
Old Jun 13, 2005 | 11:27 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Kevin, you just gave me the "I need that!" bug.
Thanks a lot.
Old Jun 14, 2005 | 10:34 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
That's pretty sweet looking. I've thought about doing the white gauge face look, but haven't been able to find any that has the '82-'84 look. I never really thought about a speedometer swap becasue I too didn't want to convert to electric but now that I know the camaros were mechanical I might think about doing it. I wanted to go the cheap route and try to make my own gauges but couldn't really figure out how to do it since the 82-84's are different. The numbers are actually printed onto the gauge, not like an overlay for later years. I got a spare cluster to try and figure something out but kinda just let it go. My question is how do you fasten the white face gauges on the stock cluster? The only one that has screws is the speedometer...and since you changed it for a Camaro speedometer I don't know about that one. The other gauges...tach, volts, oil, fuel and temp don't have any screws, only rivets where the actual gauge is fastened onto the back. Did you just use double sided tape or something?
Old Jun 14, 2005 | 11:01 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Back in the early 1980's there were a few companies that made160MPH speedometers for 82-84 Firebirds.
I just read in a recent Pontiac magazine that a company has started to make 160MPH for 82-84 Firebirds again. Their website is www.autoinstruments.com It looks just like the versions that Mecham and T/A Specialities made back in the day.
Old Jun 14, 2005 | 12:57 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The T/A Specialties is a 155mph mech gauge.
This came out of my friends 82 Trans Am,
Old Jun 14, 2005 | 04:52 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
I'll have to check out that company. I like the black face gauge better because I'm trying to go for a stock looking apearance.
Old Jun 14, 2005 | 09:12 PM
GarageToys's Avatar
Originally posted by 1982TA
...My question is how do you fasten the white face gauges on the stock cluster? The only one that has screws is the speedometer...and since you changed it for a Camaro speedometer I don't know about that one. The other gauges...tach, volts, oil, fuel and temp don't have any screws, only rivets where the actual gauge is fastened onto the back. Did you just use double sided tape or something?
Actually, I sent my cluster to Scott and he took the needles off, made the custom faces, painted the needles and put it all back together. I received it just like you see it.
My cluster was his prototype, so I dunno if that is his standard procedure or if he just sends you the faces now that he's made up a template. If someone is interested in a set of these, contact Scott and post in this thread how he goes about it.
Jorlain
Aug 24, 2022 05:11 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
E Rod
Aug 28, 2015 05:17 AM
Greg '85 T/A
Aug 14, 2015 01:40 PM
beachrodder
Aug 7, 2015 04:27 PM
