Rear louvers
Old Jun 19, 2005 | 10:06 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Rear louvers
Does anyone know if there is a way to dissasemble factory 91rs rear window louvers? Tryin to break them down so i could ship them if i found a buyer.
Old Jun 19, 2005 | 10:30 PM
ssean92's Avatar
Car: sold
were u at and how much u asking for them
Old Jun 20, 2005 | 02:43 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Yeah.......how much u want and where u at? That's the last thing I am missing from my RPO list....
Old Jun 20, 2005 | 02:46 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
The louvres on my 84' are three piece. I don't know if they are aftermarket or not. The upper hinges on the main piece have the mounting bolts going right through the glass. It's the first car I've owned with louvres, so I am not sure. Are your's one piece louvres?
Old Jun 21, 2005 | 01:36 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
CAn you post a picture of yours?
I'm in washington, lookin for 150 plus shipping, i'd really like to figure out a way to take em apart so shipping wouldnt be very much, 10-15 bucks probably if i could get them taken down... They're in pefect condition with all hte mounting hardware.
Old Jun 21, 2005 | 03:04 PM
Zed'er's Avatar
Car: 84 Z28HO
Here's the only pic i have right now. I can take some more later on when I get home.
http://www.cardomain.com/memberpage/722066
Old Jun 22, 2005 | 03:37 AM
911rsq's Avatar
Transmission: yes
Do you have them off of the car yet?
If I recall correctly, my old set had bolts or screws of some type that would seperate the outer 2 side pieces from all of the center slats. It would break down pretty easily. It's been years since I have had that set tho......
ajtobutwicz...... is this the factory style louvers for the '91 Camaro's? If it is I am VERY interested!!!!!!!
Old Jun 22, 2005 | 10:46 AM
Bad5OGT's Avatar
Car: 1986 Ford Mustang GT
Engine: 5.0
I found some aluminum 3 peice window louvers for my dads Camaro while I was in California. Bought them for $40 and it cost me $105 to ship via UPS But they look sik on there. If I knew how to post pics I would.
Old Jun 22, 2005 | 11:14 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
$105? I paid $15 for my louvers and it cost me $15-20 to have mine shipped here.
Old Jun 22, 2005 | 12:07 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Louvers on my 88 are three piece, aluminum in the center and plastic on the sides. Look to be glued together with a metal strip that is clinched to the slats also. Mine don't look like they would come apart without destroying them.
Old Jun 22, 2005 | 01:49 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The factory louvers have small locking tabs on the edges of the side ABS that grab the slats. The slats are glued to the side ABS with a black silicone caulk. Seperating these will not be easy. If you look at the bottom side (window side), you'll see the small rectangular hole that the tabs lock into. If you seperate them, you'll probably need to clean all the adhesive off before they can be reassembled.
Zed'er, your louvers are aftermarket. The factory set installs somewhat quickly. There are 4 brackets that slide over the side of the rear window. They too have small locking tabs that hold them to the window trim. If they don't get spread apart at the window trim, the trim WILL be scratched when the brackets are removed. There are 2 brackets that slide over the trim at the top of the window. Those brackets have double sided tape to hold them in place also. There are also 2 screws welded to those brackets that allow the louvers' hinges to attach. Then the last 2 brackets sit on the window with double sided tape. This keeps them from rattling. They are anchored down very well.
Old Jun 22, 2005 | 02:29 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Thats what mine look like, yes, they are the 100% factory original louvers.
Old Jun 22, 2005 | 02:32 PM
Zed'er's Avatar
Car: 84 Z28HO
Yeah, I kinda figured mine were aftermarket. I took a closer look at them, they are Shadow-something-or-other. They are aluminum, three piece louvres. The center section only connects to the side pieces with two locks at the bottom. Flip the locks open, and the center piece lifts up and has two support legs to hold it there for window cleaning. Still though, I took them off when I first got the car to clean them up, and I think it looks much better with them on.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
