ugly stuff around t-top
Car: 89 camaro rs
Engine: 305 tbi
another t-top question. this time its a little different. there are no leaks or anything. but there this sort of stripping stuff on the outside (on top) of my t-tops. it is shredding and an orange tubing is coming out. looks nasty. i would post pics if i had a camera and the know-how to upload them. so u guys know what this stuff's called? what its for? who sells it? and even if i could do without it? thanks.
-daniel
-daniel
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Sounds like the t-tops are an aftermarket set made by Cars and Concepts. Mine are doing the same thing and the only place that carries replacement parts for those is The Sunroof Doctor and be prepared to be shocked when you see the pricing.
They are called T-Top "P" Seals
These are the felt strips that go across the front & rear of t-tops.
Car: 89 camaro rs
Engine: 305 tbi
wow, that was quick. umm yeah i think thats them. are these u are refering to on the t-tops or the car? mine are on the car and held on with a piece of trim that runs along the front and back of the tees. ill check out that site for what ive got. thanks
Car: 1987 GTA
Just tried to get a pic or two and they didn't turn out right. That group will have everything you need to get the t-tops back right.
Car: 89 camaro rs
Engine: 305 tbi
thats alright. i checked out that site and me being computer illiterate, i couldnt find the exact stuff i found the t top parts, but not that. thanks for your help. i think im going to look closer at it and see if it would be alright if i cut that stuff off.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The "p" seals Klortho mentioned is the part you need that has the 'orange tubing' poking through. They are part of the trim on the body that covers the hack in the roof from where the tops were cut in. Replacement is the only option if you're planing to kep and use the tops.
The other option is to clear silicone them in like the previous owner did to my old (ex) 84 camaro (oddly, they leaked worse sealed up than after I peeled all the slicone out and used them as normal).
Sucks to own oddball tops...
Car: 89 camaro rs
Engine: 305 tbi
BTW did u say that your old ttops were siliconed in? or the "p" seals were?
EDIT: i found them on sunroofdoctor. they $43.?? each, and i need two
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
I pulled that ugly orange tubing right on out. My tops still dont leak. The only thing those were good for were flailing behind me while driving on the highway, and making me look like a retard. They come out in two long pieces anyway...pull em! lol
Car: 1987 GTA
The P seals are actually there to help with the sealing of the t-tops. When mine went out, it started leaking a bit around them.
Engine: TPI 305/ v6
Car: 89 camaro rs
Engine: 305 tbi
The tops.... roughly about 1.5 tubes per side
thats some crazy stuff. i couldnt handle that. if i got tops, i'm gonna use em!!!
... Last edited by dan_o_89_rs; Jun 28, 2005 at 11:00 PM.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I took mine off years ago.Still no leaks to date.They are more for keeping excess dirt/water or debree out of the channels.Perhaps so water doesnt build in there up when it rains or washing your car.They also just stick on, the back has an adhesive.
Elephantismo
Feb 13, 2019 12:51 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
