how to stop this leak
Old Aug 24, 2005 | 11:11 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Everytime it rains, water comes in here. It basically ruined my seat. I think its from the t-top sitting to far back. The weatherstripping is in good condition. I can get more pictures and info if needed.
Old Aug 24, 2005 | 11:57 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
You mean further in towards the inside and not right there at the glass/ws area right? Could be from anywhere and just happen to drip in that area. Take out the t-roofs and pull back the ws a bit and see if you can find any areas that need sealing ect. Sometimes leaks form between the t-roof glass and the metal bar on the edge of the t-roof. The piece with the handle on it. If it's there then an easy fix is tape off both the glass and the metal piece then apply a bead of black urathane caulking. Remove the tape and it looks real good and the leak is gone.
A good way to find more difficult leaks is to soap up the area real well on the outside then take compressed air inside the car via the hatch and have someone watch for bubbles while you hit it with a blow off gun.
Old Aug 25, 2005 | 08:00 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Have you tried adjusting the t-tops yet? The female receivers on the car can be adjusted up-down and in-out. If you snug the front down a little bit more, you might improve it.
If that doesn't work, your seals may just be too old and may need to be replaced. That spot that leaks is where the t-top seal and the window seal join, and if one or both is old, cracked, or shrunken slightly, you'll get a leak there.
Third option is to see if there's any adjustment in your window track. You may be able to raise the window slightly in order to press on the seals a bit more.
Old Aug 25, 2005 | 10:41 PM
Car: 91 Camaro RS
Is there any adjustment front/ back direction of the t-top?
Old Aug 26, 2005 | 01:23 AM
Vibrant_Camaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
my t-top leaks in the same spot! I can stick my finger outside through where it leaks, i have no clue what to put there either...
Old Aug 26, 2005 | 08:53 AM
Jim85IROC's Avatar
No, but since that gasket is angled, pulling the t-top down farther will tighten it up.
Old Aug 27, 2005 | 10:09 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
gladstone
My leak there was solved by taking that black metal strip off and re-sealing it to the t-top .... might want to try that
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85 Jimmy
Sep 30, 2015 07:56 AM
84redta
Sep 19, 2015 09:58 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
