Not that its bothering me.... but where are all the interrior lights?
Old Sep 17, 2005 | 01:47 AM
NEEDforSPEED's Avatar
my dome light is the only light that works, but im sure **** theres more, iv seen a wire with a plug for a light when i pulled out my ECM, j/w where the rest are in are cars....
Old Sep 17, 2005 | 02:44 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
umm passenger area (the one you found), drivers side same place next to the door, and as far as i know jut the tiny bulb that barely puts out an light under the center vents in the dash.
Old Sep 17, 2005 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dome, overhead console map lights, perhaps lights in the mirror, driver and pass side kick panel area, console clock, hatch area--dash lights, radio, HVAC, rear defogger, of course, etc.
JamesC
Old Sep 17, 2005 | 08:39 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
What year did the map lights start in the rearview mirror? I know my car doesn't have them in 86, but my 89 did.
Old Sep 17, 2005 | 10:58 AM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I only have the dome light and the map light in the rear view mirror. There are more?
Old Sep 17, 2005 | 12:19 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
there are lights illuminating the floor on your kickpanels, and one in the hatch right under the latching mechanism
Old Sep 17, 2005 | 01:14 PM
82knightrider's Avatar
Transmission: TH200C....700R4
and there the same bulbs as the side exterior side markers
Old Sep 17, 2005 | 01:21 PM
Scheister's Avatar
Car: 85 IROC
Originally posted by 87CIZ
... tiny bulb that barely puts out an light under the center vents in the dash.
huh, never seen that one
and jamesC, where exactly is the rear defogger? i cant find the sucker for the like of me.
Old Sep 17, 2005 | 05:59 PM
JamesC's Avatar
Ooops That's rear defroster (the switch is located below the cigarette lighter).
JamesC
Old Sep 17, 2005 | 06:42 PM
Scheister's Avatar
Car: 85 IROC
JamesC
oh maybe thats why i could never find it... thats where my dad put the nitrous arming button. i wonder if the wires are still back there...
Old Sep 19, 2005 | 07:13 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Same here, the only light that works on the interior of my car is the dome light. Anybody know what it could be? Is this a common problem in 3rd gens or somtin?
Old Sep 19, 2005 | 07:36 PM
Scheister's Avatar
Car: 85 IROC
burnt out light bulb?
Old Sep 19, 2005 | 09:01 PM
all mine but the dome light are missing so ya that could be the problem
Old Sep 20, 2005 | 12:41 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
Hey I want the floor lights, but i dont have the wires. How would i go about putting some in?
Old Sep 20, 2005 | 03:51 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My vert is like this. Didn't come with the floor lights. Are all verts like this or am I just a freak?
Old Sep 20, 2005 | 08:34 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
any one able to take a pic of these "driver and pass side kick panel area lights" i have never seen them or heard of our car having them. what years did they come on our cars?
Old Sep 20, 2005 | 08:50 AM
JamesC's Avatar
My 85 IROC has the "floor/courtesy lights" (the bulbs are 631s). There are holes in the upper plastic panels (the ones above your feet). The bulb's socket twists into the holes from above. The holes are a little bit dimpled, so you may have to look closely or run your hand over the area. I figured all cars had them.
JamesC
Old Sep 20, 2005 | 10:30 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I added the 4th gen rear view mirror with the 2 lights in it.
All of the 3rd gen birds I've had had the floor lights in them.
If you look at the clutch pedal, right above it is the floor light
and there is a light right above the heater controls
Old Sep 20, 2005 | 10:50 AM
JamesC's Avatar
The Camaro versions do not have lense covers and are more unobtrusive.
JamesC
Old Sep 20, 2005 | 08:51 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
my 86 has all of these lights. did you try turning the headlight pop out switch to the left till it clicks? this turns on all the other lights. when you turn it to the right it dims the gauges and radio/ac controls, but when you turn it to full illumination and then even more to the left all the lights come on. as far as i know, thats the only way to turn them on. try it when its dark.
Old Sep 20, 2005 | 09:18 PM
Car: 1997 S10
is this where it is supposed to be in my 91 RS on the passangers side?
Old Sep 21, 2005 | 02:46 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
my 85 iroc has the dome light and the two floor lights
thats it though
Old Sep 21, 2005 | 09:44 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
I believe they were only on the higher optioned/model cars such as the Z28's and IROC's etc... I may be wrong though.
Old Sep 21, 2005 | 09:52 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
The dome light in my bird does not work, and I can't figure out why. I put in a new bulb and replaced the fuse, but still nothing. I need to do an electrical current test, but I haven't got around to it.
Old Sep 21, 2005 | 10:02 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Just be advised the dome lights have kind of a weird wiring set up.
The little push switches in the doors provide the ground for the circuit to turn on the dome light. That one threw me for quite a while until I figured that out.
You might want to check those switches if your dome light isn't coming on.
To add a floor courtesy light (which I've been meaning to do), theoretically all you would have to do is tap into fused power for one side of any added light socket and tap the other side of the socket into the door switch wire. Voila! Floor lights come on when you open the door!
Old Sep 21, 2005 | 01:32 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Bimma86 I believe they were only on the higher optioned/model cars such as the Z28's and IROC's etc... I may be wrong though.
um, i have one of those
Old Sep 21, 2005 | 02:04 PM
JamesC's Avatar
irocberry,
I'd be surprised if you didn't have the rear 'cargo' light--this one must be switched on my hand.
JamesC
Old Sep 21, 2005 | 02:45 PM
Scheister's Avatar
Car: 85 IROC
irocberry,
JamesC
gotta love that one! its so easy to forget its on and itll drain your battery overnight.
Old Sep 21, 2005 | 03:15 PM
Car: 1997 S10
so does anyone know if that is where my floor light is supposed to be http://putfile.com/pic.php?pic=9/26221163941.jpg&s=x1
Old Sep 21, 2005 | 03:37 PM
JamesC's Avatar
Well, 91, that hole seems to be the place where the sock plugs in.
JamesC
Old Sep 21, 2005 | 04:02 PM
Car: 1997 S10
JamesC
man i wounder why anyone would take out the socket and not put it back oh well i guess my passangers do not need to see there feet at night
Old Sep 21, 2005 | 04:06 PM
JamesC's Avatar
Maybe the light/socket is tucked up in the dash for some reason. Take a peek.
JamesC
Old Sep 21, 2005 | 04:09 PM
Car: 1997 S10
i think i will man that would be cool if it was up there.
Old Sep 21, 2005 | 08:03 PM
elky74's Avatar
Thanks VERNW, my domelight now works after fartin' around with the fuse box and the door switches. Weird thing is, if you open the passenger door only, it won't work. Oh well, I'll be by myself in the car most of the time. I also found the floor lamp socket and put in a bulb from my El Camino side marker, it works! I don't see a light above the heater controls though.
Old Sep 21, 2005 | 11:46 PM
vernw's Avatar
No problem, glad I could help. Chances are the passenger door switch is dirty or bad, or the wire going to it broken somewhere....
Old Sep 22, 2005 | 12:58 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
sp exactly where is the cargo one supposed to be, havent found one in the 4 years ive had the car
Old Sep 22, 2005 | 06:07 AM
JamesC's Avatar
Just below the hatch mechanism inside the car.
JamesC
Old Sep 22, 2005 | 08:24 AM
Car: 1997 S10
JamesC
well i took a look and no floor lamp when i took that panel off my computer fell out it was not even bolted in i did not even see where the wires or socket would come from.
Old Sep 23, 2005 | 01:07 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
not one there
did they start after 85 or something, cant even see where one would have been
somebody whos got a little free time mind snapping a pick
Old Sep 23, 2005 | 06:14 AM
JamesC's Avatar
The wiring to the bulb is white and orange. Sounds to me as if someone's been fooling around under the dash if the computer fell.
JamesC
Old Sep 23, 2005 | 03:48 PM
Car: 1997 S10
JamesC
yea i think so also its a real mess under there
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
