pinch welds
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
pinch welds
anyone know how much to replace pinch welds, one of myn is horrible and the other seemed fine but F*8 bent when i jacked it up the other day its def time for new ones rofl
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
pinch weld? is this the same as a spot weld, or im i lost
so what is a pinch weld? im from a long line of sheet metal workers and none of them know what that is.
ahhh that would make sence...thxs for the clarifacation
the pinch weld is the area underneath the car between the rocker and floor. the metal looks pinched together
Why do you want to replace this?
I have seen cars bottom out and mangle up this area pretty bad and every body shop wants to repair this. very easy to straighten and will look brand new with a little time spent with mr. hammer and mrs. dolly.
any way to post a pic to show us how bad it is
Axle/Gears: 3.23's
well ill grab a picture tomrow, heh basicly its rotted out bad on one side and all deformed in the front the back is fine, on the other side its better but on its way out
i wanna get it replaced and painted up before the rust spreads
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I too want to know how to fix this. some jack *** lifted my car up with a fork lift to move it and crinkled mine. they have no rust but theres no way to get inside them to pop them out. he dented my floor pan too. luckily this was a day before i got it or he would be dead.
Axle/Gears: 3.23's
couldnt get the pics today guys was pouring ill try to have em tomrow, but its sposed to rain all week end :/
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
ya man, this rain blows. I was trying to drive on the highway earlier tonight... I couldn't even see where the white lines were.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Tell me about it i tried to race a Z06 and couldnt because it started to kick sideways in 2nd. I know i would have taken him too
I was starting to pull on him in 2nd till she broke loose at 5krpm.
I will try to get pics of my pinch welds too
Theres leafs and **** suck up inside of it. I seemed to find a flaw in the design because my inside of my fenders are packed with leafs and so are my rockers. looks like a compost pile.
I was starting to pull on him in 2nd till she broke loose at 5krpm.I will try to get pics of my pinch welds too
Car: 1987 Camaro IROC-Z
Engine: LB9
i just got through straighting mine out and patching the rust that was behind there, then i get a screw in a tire last night and i took it to pepboys since they were the only one open and just about went balistic on the kid that went to jack it up by the pinch weld
Axle/Gears: 3.23's
haha, i woulda killed him to even i know when ever you can jack something by the frame you should not to mention im sure he coulda seen that it didnt look to stable
trying to grab those pics, rain has stopped for liek 20 mins ( now watch ill step outside and itll start again)
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
just a quick message to everyone that reads this post- NEVER lift your f-body by the pinchweld! You're taking a big chance that they'll crumple. There are plenty of good lifting points to use. You can use the k-member or A-arms up front and the rear axle or just in front of the rear control arms in the back. And if you have properly installed subframe connectors, you can use those too.
no green
Jan 9, 2016 09:22 PM
ive been lifting the car on the subframes
