Firebird Fender Air Extractor
Old Oct 5, 2005 | 11:20 PM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
I have two questions.
1) Are the GTA fenders with the Air Extractors the same as a regular Firebird fenders with the exception of the holes for the extractors? (i.e. Can I order the Air Extractors from Classic Industries and cut the appropriate holes for them to work with my standard Formula fenders without a lot of custom body work?)
2) Which RPO code indicated the inclusion of the Air Extractors? Was it Y84 or WS4?
Old Oct 6, 2005 | 05:03 AM
Lazer's Avatar
Car: 1989 Iroc-Z / 1985 Camaro
Engine: 5.7L 350 / 2.8L V6
3. Do they work on camaros too?
Old Oct 6, 2005 | 08:54 AM
Mr. TurboTA's Avatar
Trans Ams have the air extractors, GTAs do not.
It was near the end of the production, that none of the cars got the air extractors. 1991 to be exact.
1982-1984 style have longer, bigger openings, while the 1985-1990 have shorter, smaller openings, due to the aero package cutting into the extractor.
Hope this helps,
George
Old Oct 6, 2005 | 03:23 PM
Car: 1990 Formula
Engine: 383 Stroker
OK ....... Here's what it boils down to. Can I install these air extractors (see photo out of Classic Industries Catalog) into my standard Formula fenders without doing much else other than just cutting the holes (and, of course, having them painted)?
Old Oct 6, 2005 | 03:29 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
If you are want ing to do this you can same your self alot of time by getting Trans Am fenders that already have the holes in them
Old Oct 6, 2005 | 03:38 PM
Car: 1990 Formula
Engine: 383 Stroker
Maybe so, BUT ...........
$75 + 'Do It Myself' labor
versus
$400 or $500 + Professional Paint Job
If it's possible, I'll cut the fenders that I already have. If it's not possible, I'll just have to do without.
Old Oct 6, 2005 | 04:29 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
there is a little lip in the fenders that are made to fit the air extractors. Basically, if you took the plastic extractor out of the fender, you would see a recessed ledge in the fender that goes about 1/8- 1/4" behind the air extractor. I wish I had a picture, it would be much easier to see it than read a description. The ledge is there so that the air extractor sits flush with the rest of the fender. Also, if you don't have 85-90 ground effects on your bird, the vents from an 82-84 Trans Am would look better because the vent is longer and doesn't have that flat blank area that the ones in the picture you posted have (that area sits behind the higher 85-90 ground effects).
Old Oct 6, 2005 | 05:06 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
just buy 2 junkyard fender, bring them to a body shop and have them match the paint
Old Oct 6, 2005 | 05:09 PM
Car: 1990 Formula
Engine: 383 Stroker
Thanks guys. That was exactly what I needed to know.
Old Oct 6, 2005 | 06:29 PM
Also,
Just so you know, that picture has them upsidedown!
The big black spot is for the aero package to cover.
You could cut the holes in the fender smaller, and put these in, then bondo them to fit. But again, then you have to paint the whole fender.
I've done this on second gens.
George
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
Dialed_In
Aug 20, 2015 01:45 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
