T-Top bar rust
Old Oct 27, 2005 | 10:07 PM
Beachhead's Avatar
Car: 2006 Mustang
Engine: 4.0L V6
Transmission: Manual
T-Top bar rust
I went and looked at yet another '82 trans am today, but it had a small rust blister on the roof near the t-tops. I am assuming this is bad and unrepairable? Perhaps this means the t-tops are leaking water and its getting into the metal that way? I almost bought the car except for that. I dont know what i would be getting into.
Old Oct 27, 2005 | 10:31 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The T-top bar is just one piece of the car. Yes it's a bit expensive to replace. I got one for $154 cost from GM about 10 years ago. Now they are much more cause GM doesn't sell em' anymore. Trim pieces have always been expensive. There is a guy that sells them in the for sale fourm all thel the time for $50.
If the rest of the car is in good shape then buy it. Should be worth it.
Old Oct 28, 2005 | 02:44 AM
CrazyHawaiian's Avatar
Car: too many ...
The black T-top bar is removable. If it is rusted then yes water is somehow getting in and the weatherstripping probably needs to be replaced as well. I would recommend removing the t-tops, dropping the headliner, and removing the black T-top bar. Then you can see if the body of the car is rusted or not. You can do all this with hand tools in about 5-10 minutes. If the guy selling it wont let you do this dont buy it. My old RS had a similar problem, and while I thought only the black T-top bar was rusted, the actual roof of the car under the headliner was rusted as well. It was bad. I got a replacement T-top bar from the local dealer for $125 like a year ago, sold it to another member for $75 after the car got sent to the scrap yard (partly because of the rust which has spread all over, partly because of other reasons).
Old Oct 28, 2005 | 02:55 AM
Willbanks's Avatar
Car: 1991 Z28 Camaro
I just repaired a problem like this. I used bondo and sealer.
Maybe it's not the same problem your talking about ... here is a pic of the rust
Old Oct 28, 2005 | 06:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, that car is garbage then, destined for a quick trip to the scrap heap, irreparable, and junk.
Old Nov 12, 2005 | 12:11 AM
Beachhead's Avatar
Car: 2006 Mustang
Engine: 4.0L V6
Here is a photo of the rust on the roof. What do you guys think after seeing this? Still the same conclusion?
Old Nov 12, 2005 | 01:01 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Mine has a little of the same. It's not that water is getting in, it's that it is not draining out of the weather stripping areas.
Jim.
Old Nov 12, 2005 | 01:08 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Take it to a body shop you trust. Have them look it over. If they say they can fix it, then go for it. Even if it requires being cut up a bit to get all the rust out, I'd go for it. BUT ONLY IF I LIKED THE CAR OTHERWISE!
1982 was the first year of the 3rd gens, so almost anything else is going to be newer. Newer means less problems all around, and believe me, YOU WILL HAVE PROBLEMS.
Old Nov 12, 2005 | 01:13 AM
Engine: SBC, LS-x
You needed new metal. Betya it will be back worse than ever within 3 years.
Old Nov 12, 2005 | 01:17 AM
Engine: SBC, LS-x
Minor problem if you bring everything else into the picture. What do the lower wheel wells and the drivers side rocker panel right at the pedal area look like?
Good?
Sounds like a real fixer upper!
Bad?
Don't buy it unless you like rust.
Old Nov 12, 2005 | 11:50 AM
Beachhead's Avatar
Car: 2006 Mustang
Engine: 4.0L V6
I'm going to look at an '85 today, maybe it will be better.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
codeysabatini
Sep 20, 2015 11:36 AM
m00n420
Sep 11, 2015 02:39 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
