New Shift Knob
Old Nov 7, 2005 | 09:59 PM
mr_han_solo's Avatar
Car: 1986 Camaro Coupe
Engine: 2.8L V6
New Shift ****
Hello,
I bought this shift **** off ebay: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWN%3AIT\
From what I read it should be a direct bolt in for the camaro. But it seems that when I slip it on that something is keeping it from slipping down the shifter shaft all the way. Can anyone help me solve this problem?
Han
Old Nov 7, 2005 | 10:16 PM
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Make sure there isn't a set screw that is threaded in already because im pretty sure most aftermarket shifters use this method, also i did not see it saying it fit a camaro or f-body in general only a fiero and grand-prix which should still work....but keep that in mind also and goodluck
Old Nov 7, 2005 | 10:29 PM
MNformula350's Avatar
Did your car originally have the round ball shifter? the one with the snap rings on top to hold it on. if so you are going to need a different shifter assembly to use that ****. The round ball auto shift ***** on the 3rd gen camaro's pretty much only fit the ball, they are not set up the same with the c clip like the later camaro's and all the Firebirds. and 90% of the GM cars made in the 80's and 90's.
Old Nov 7, 2005 | 11:14 PM
True_bird's Avatar
Car: 1985 Firebird
I still think that that shifter should work even if he had a ball shifter with the c-clips just instead of using the c-clips you are using the setscrew to hold it down, or that shifter could be like mine where in the front there is a little metal tab/clip thingy that u just pull out now if you had the ball shift **** before i am unsure about using the t style handle...someone else have imput?
Old Nov 8, 2005 | 07:23 AM
Engine: 2.8L V6
Yes,
I had a ball shifter, so i'm going to need to look into getting an assembly off a later camaro/firebird correct? Does anyone know of what year models i'm gonna need?
Han
Old Nov 8, 2005 | 07:58 AM
True_bird's Avatar
Car: 1985 Firebird
Well i am not even sure if camaro's had a T style shifter but i can tell you forsure firebirds came with them so if u had to im sure you could convert the shifter shaft to a firebird shaft and then it would more then likely fit, but what method does your aftermarket shifter use to hold itself in place does it have a set screw or that flat horizontal tab,or a c-clip(doughtful)
Old Nov 8, 2005 | 01:28 PM
Engine: 2.8L V6
THe aftermarket shifter, uses a flat staple like thingie a the bottom to hold it inplace.
Old Nov 8, 2005 | 03:12 PM
True_bird's Avatar
Car: 1985 Firebird
then it is using the same method as firebirds use to hold them on with the flat tab thing and as you used to have the c-clip style i am now unsure if that is compatible with your shaft, would someone that has a camaro like to give some advice?
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
