impact bar question
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: impact bar question
Originally posted by stocker85
are all impact bars the same (part that honeycomb bolts onto) for all 3rd gens?
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
deadbird, that is a very valuable site you have there! That will be very useful this spring when I fix the previous owner's half *** collision repair job.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Hmm....but wil lthey all more less bolt together? Like will a camaro impact bar bolt onto a Firebird?
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
not sure about camaros but i had one from a 92 i wanted to use because it was in really good shape but it wouldnt work on my 85.....the honeycombs pushed out on the bumber cover and you could see it through the cover the ends on the 92 were straight and the 85 ends were cut at a 45 degree angle.....it bolted right up though, just had problems with the bumper cover......i could have probably use it with a little cutting but it was just as easy for me to send the right one to be sandblasted
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
Has anyone removed their front impact bar? It would free up some weight, but has anyone done it? I'm considering doing it.
It ties your front frame together and immensely helps distribute impact energy thru the whole car instead of directly wherever you get hit.....
But what goods safety pieces.. dead weight apparently
ProtoMaster22
Aug 26, 2015 07:50 AM
