Rims questions
Old Dec 7, 2005 | 08:12 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Rims questions
i kinda purchased some rims and um now im startin to wonder if theyre gonna fit my car. maybe you guys could help me out. ok i got a 87 IROC pretty much stock suspension right now i just got springs like sportlines and i just purchased these rims. will i be able to run these rims with or without the lowered springs or can i even use them? they are C5 Corvette style wheels, 17x9.5 with a 53 mm offset. heres a pics of the rims.
Old Dec 7, 2005 | 08:13 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
you're gonna need spacers
Old Dec 7, 2005 | 08:20 PM
Car: 1987 IROC
i actually have the spacers im jsut wondering about like the top part of the tire rubbing. sorry i forgot to mention that
Old Dec 7, 2005 | 10:32 PM
Im sure you'll be fine as long as you wrap them in the right profile rubber....Im not sure on the size for 17's....but take my rear 18x10's for example...I run a 35r...keeps them the stock height and I havent had any problems....Im sure someone with 17's will chime in for ya
Old Dec 7, 2005 | 10:36 PM
Car: 1987 IROC
well my friend thats gonna hook me up at discount tire said that i should run 245x45x17. i think thats what he told me. i wonder if anyone can photoshop those rims onto my car so i can see how theyll look. but for some reason no one likes to reply to any of my posts. oh and thatnx for replying.
Old Dec 8, 2005 | 12:54 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
245/50/r16 (stock) and 245/45/r17 as your friend suggested are extremely close diameter wise so they won't look goofy and your speedo won’t get affected. Tire (rubber) diameter will remain almost the exact same.
I question the width though. You said your rims are 17x9.5. You could easily run a much wider tire. Heck, the stockers run a 245 on an 8" wide rim. I would go with a 305 (305/35/r17) on the rear and call it a day. Might stick with a less narrow tire up front for looks and so that your wheel won't get yanked around as much.
Old Dec 8, 2005 | 02:03 AM
a 305 on a 9.5" wheel is a little wide dont ya think? Im running 10" on my rear wheels and only sport a 285 and they fill in nicely, a 295 would be about the max Id go on my 10s
Old Dec 8, 2005 | 12:03 PM
Gummie's Avatar
Car: 88 GTA
You're right. I just did a quick little bit of math and keeping the same tire/rim ratio as stock you would want to run a 290 on 9.5" wide rims.
Old Dec 8, 2005 | 04:40 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
___/40/17 will work for tires, i dont know what width you need, but i have 17" ZR1's and i dont rub with 40's
Old Dec 8, 2005 | 07:23 PM
Car: 1987 IROC
will i still be able to lower my car 1.75"?? and not rub like nasty style?
Old Dec 8, 2005 | 10:33 PM
Gummie's Avatar
Car: 88 GTA
Overall tire diameter won't change, so it wont impact lowering. As long as your suspension is stiff enough you shouldn't bottom out.
As for tire size, check this out: http://www.miata.net/garage/tirecalc.html. The first number is tire width in mm, the second is a ratio between width and rimsize for sidewall, and the third is rim size.
Old Dec 9, 2005 | 12:34 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
i think id run 305s on the back, you wont have any problems.
Old Dec 9, 2005 | 01:03 AM
Car: 1987 IROC
what you guys think about like 275's in front and 305's in back would that work?
Old Dec 9, 2005 | 03:13 AM
BlueZee28's Avatar
dont see why not. i know my 275/40/17 doesn't rub at all...i haven't lowered my car so i don tknow about that, but it works fine the way it is
Old Dec 9, 2005 | 06:06 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
eibach pro kit, 18's in back, and here's a pic. I'd run 275's all around in the interest of rotating the tires, and it'd be cheaper than getting 305's.. can't wait to see them on your car, man! what are ya gonna do with your crosslace wheels?
Old Dec 9, 2005 | 06:55 PM
Car: 1987 IROC
i might be giving them to alex for trade in price for those other things i put on my car. hopefully soon ill find a dang front end so i can throw her in the paint shop.
Old Dec 17, 2005 | 04:38 PM
Car: 1987 IROC
well the rims are on now what u guys think??
Old Dec 17, 2005 | 07:32 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
LOOKS GOOD!
What tire sizes did you end up going with?
Old Dec 17, 2005 | 08:43 PM
they actually dont look bad...the fact that they are 17" lets you run your stock brakes without lookin dis-poportioned.....the rear sticks out a little too far though
Old Dec 17, 2005 | 10:20 PM
Car: 1987 IROC
i went with 245/45/17. there was alot of clearance issues thoguh. we had to cut some of the strut and shave the tie rods and put 3 spacers in front. but yeah they do stick out kinda far in the back im not even sure if im keeping them. i might sell them cause i dont like chrome. or mayeb get them powder coated black.
Old Dec 18, 2005 | 02:20 AM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
I think they look great!! Ive always loved the way Y2k C5 wheels look on our cars. Do you have a shot from the rear so we can see how far they stick out? Are you using 2" spacers in the rear? Thats weird that they stick out that far unless its not as bad in person. Edit: 2nd look they dont look too bad actually. Once you lower it if you can it will probably look better.
Old Dec 20, 2005 | 02:54 PM
Car: 1987 IROC
ok i dont like them anyone wanna buy them? pick up only! no spacers.
rims costed $455
tires costed $250
mount and balance and everything costed but im not gonna throw that in with the price.
ill sell them for $600
set of four brand new chrome C5 Corvette style wheels, 17x9.5 with a 53 mm offset. Made to fit Corvette, Camaro, Firebird, Trans Am.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Djmathis123
Sep 29, 2015 01:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
