please help rivets
Old Dec 19, 2005 | 12:06 AM
restored92's Avatar
please help rivets
how do you get rivets out ive tried drilling them but it goes no where, just spins on top of the rivet from the back side, but when you hit the face it will drill thru but the pieces still dont come out
Old Dec 19, 2005 | 01:31 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
A pair of Dikes (wire cutters :P)
Old Dec 19, 2005 | 06:54 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
You're doing something wrong. Are you using a large enough diameter drill bit? Did you remember to knock out the center steel pin with a punch first? If the rivet spins just hold it with a needle nose pilers or Vise-Grip.
You should be able to drill out the rivit in under 30 seconds.
grafx
Oct 18, 2024 12:43 PM
mav75
Aug 31, 2015 12:16 AM
ViciousZ
Aug 7, 2002 09:06 PM
ronterry
Apr 24, 2002 08:21 AM
