Let's Help Me Out.
Old Dec 23, 2005 | 12:53 PM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Let's Help Me Out.
Mods, sorry if no double posting? allowed. I stuck this in exhaust, but I thought maybe I'd get more responses here too.... If a prob, do ya' job!
Hey guys... Thanks in advance to anyone who can help a girl out!
I have a 1984 Firebird S/E V8, 305 carb.
Lately I've noticed a funky @$$ hesitation when the car is going changes gears.
So basically, it feels like I'm driving a stick shift even though I'm not.
Secondly, sometimes it... lurches? I guess would be the best word to describe it. I'll be at a complete stop, idle is around 600 rpm based on my tach. and give it gas, the car feels like it's gonna die!!!! I KNOW I have gas in it, 91 octane, b/c I keep it on a full tank. Don't ask why, I just do.
So, checked my fuel line, it's fine. Checked my fuel filter, whatdya know... It's fine too.
Took it to my cousin who owns a mechanic shop, he says go get your catalytic converter replaced. So I do.
Which helped...
a. It sounds ALOT better.... Like ALOT.
b. It runs better than it did before, but not like it should.
So, now I'm a bit stumped as to what to do...
Anyone got some hints?
I'm trying to knock down every option before I take it in again, even though he's family, busta's gotta turn a dolla'. LoL. JK. I'm a poor starving college student in addition to the fact it's Christmas time... Enough said.
P.S. My stock catalytic conver. was internally combusted.... hehe.
Oh yeah. I sing. exhaust w/ dual tips... The stock muff. was replaced with a 80 series Flowmasters, I think... (Blonde moment...)
Old Dec 23, 2005 | 01:36 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I had a similar problem a couple months back. After about 2 weeks its stop trying to die at stop lights and stop changing gears funny. The only thing I did was change my O2 sensor and I started running the car through the gears when I left a stop light.
The O2 sensor is like a 10$-15$ part so might not hurt to try that.
Old Dec 23, 2005 | 01:40 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
maybe just give it a tune up ? new plugs, wires cap thats sorta thing
Old Dec 23, 2005 | 01:48 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
If you don't need to run 91 octane then don't, all you doing there is wasting money, seriously it will. Running higher octane can sometime cause problems.
But try running a basic tune up, spark plugs, wires, cap and rotor. I check that cap and rotor make sure it is ok. My camaro would hesitate or suddenly act like it was going to stall then it all of a sudden it move, shortley later the plug wires got burnt because the cap of the distrubuter came lose and turned. So check that. Also couldn't hurt to check a coolant sensor if you have one, not sure if carbs have them so.
Old Dec 25, 2005 | 03:19 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
are you talking about when you take off and the car kind of jumps forward violently (not HORRIBLY violent, but you get the picture)
because my car does it too, but its a stick. and i have no idea how to fix it... i need a new fuel filter bad though, maybe thats it? clogged filter?
Old Dec 25, 2005 | 09:32 AM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
My car use to shake alot when I first got it.. 2 spark plug wires were off. I dont kno what else it could be besides your tune
Old Dec 25, 2005 | 10:40 AM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
running a higher octane on the larger engines doesnt do damage it accualy helps a little on milage .... now if you have a four or six cylender it can give do some damage because it ignites at higher tempuratures, you wont knowtice to much of a differnce using it but if you had a turbo or supercharger theres a big difference it all has to do with compression
ok back to the subject.... might want to take a look at the carb see if that could be teh problem othere wise i would def inatly try the o2 sensor its cheap and could be it
Old Dec 25, 2005 | 07:15 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
my question is why did this get posted in "body and interior"
Old Dec 26, 2005 | 03:52 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
That's a good question.....?????
Bubbajones_ya
Jul 6, 2024 08:32 PM
RedLeader289
May 28, 2019 01:47 PM
mattcanty
Oct 12, 2015 11:08 AM
mfp189
Sep 27, 2015 09:25 AM
earlpote
Sep 12, 2015 11:55 AM
