WANTED: DETAILED instructions: How to replace Power Window Motor
Old Dec 24, 2005 | 01:36 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
I would like to replace my Driver side power window motor. I have never done this and am worried about the HEAVY window (which i've heard can slice off fingers [scissor type mechanism] ) glass..
Does anyone have a DETAILED Step-By-Step (pics would be fantastic) of replacing one from a 1992 Camaro.??
Old Dec 24, 2005 | 07:16 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
there is a tech article,as well as some threads about it,do a search and you will find those posts,it looks harder than it actually is though
probably a 6 hours job
Old Dec 24, 2005 | 10:55 AM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
If you are intimidated by the thought of loosing fingers or worse messing up your door, try the easy or "hack" way. Just drill out the rivits that hold the motor to the door and the motor will slide out.
I did one motor swap in 30 min without even taking the door panel completely off. (I only had 30 min.) Use loctite on the bolts that replace the drilled out rivits or you will be back in there to tighten them.
Taking the whole assembly out to clean and lube it up is the proper way.
Tech article:
https://www.thirdgen.org/newdesign/t...rwindows.shtml
Or search window + hack
Old Dec 24, 2005 | 11:36 AM
Stevo's Avatar
Car: Pair of 92 Z28s
It aint easy and it aint fun...well its easy once u understand all the parts but its just a royal pain in the ***. It was for me and i had assistance. How did everyone hold the window up?
Old Dec 24, 2005 | 12:47 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Read this before you dig in
doin it the way it is described in this TGO thread i would say it is in no way the hardest thing taht i have ever done to my car.
Old Dec 24, 2005 | 04:15 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
you can loose a finger doing this???
Old Dec 24, 2005 | 10:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes, do a search, there are excellent threads on it (as you've probably found by now).
Usually you don't need to replace the motor, just the brushes. That can be done without even removing the motor from the car, just use a short flat blade screwdriver.
I got a power window motor from an '82 caprice or something, replaced my drivers side, then just put new brushes into the passenger side one....
Old Dec 25, 2005 | 09:20 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
i almost lost a finger doing this job. driver side spring snapped and tracks i think got my finger broke it at the knuckle and long ways down my finger was in a cast and all. then i lost use of my finger cause of tendons fusing to the bone i couldnt move it so about 6 months later after the bone finally healed they had to do surgrey on my finger and cut the tendons lose and then i had to go to therapy. it sucked and after all that i it both windows done for 100 bucks so to me that wasnt worth it i just payed someone to do it.
Old Dec 26, 2005 | 02:12 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
holy crap. talk about worst case scenario. sorry to hear about that man
Old Dec 26, 2005 | 02:50 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Did both my windows and now both work when they feel like it. I hate our windows. There slow and fail constantly. Another item these cars need an aftermarket for.
Old Dec 26, 2005 | 02:55 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
I got some manual tracks and cranks off ebay and I hopefully will be installing them soon. hopefully without any more brokeing fingers. i figured its going to save me some weight and it will be much easier then wondering if they going to work today or not. i jsut have to get my door panels remade or cut for the crank, and i already had a console that has no holes in it. so i just need to do it.
Old Dec 26, 2005 | 07:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
huh, you're "upgrading" to manual windows....
boy, niche market there...
I think with a bit of work, greasing tracks, new brushes, maybe upgrading wiring if you want it to work like a new car, and you're set.
I didn't have much problem with it..
Old Dec 26, 2005 | 07:33 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
they work but there just slow, have to open door to get it to go all the way up with new weatherstripping.
Old Dec 28, 2005 | 07:49 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I did the 'hack' way, very easy.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
