digital dash help
Car: 2003 ford mustang gt, 1987 trans am gta convertable
Engine: 4.6 in the mustang, 305 in the trans am
Transmission: both are automatics
digital dash help
hey everybody long time no talk.. hope everybody's holidays are going well, well as some of you know i have a 87 gta vert that iam doing an interior resto on this winter, but i have a question about my digitial dash all the gauges work fine expect the trip and odometer secition, now when i start the car it comes on for like 2 minutes then it fades out and doesnt work, if i were to buy a dash can just that section be replaced, or if anybody has taken these apart how hard is it to do, and were would i find the wires for that section to make sure nothing has happend to them.
thanks for the help
steve
thanks for the help
steve
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
They can be taken apart.... I have 2 and have disassemble them a couple times.... When you take off the Middle A/C trim they are right there a couple clips and/or bolts holding them in.
There is a place by me called Techncar. They had two left, one of each part number for the GTA. I don't know if they can get mopre or not but I will check for you if you like. You need to pull you cluster since it is on exchange basis. the part numbers for the 88 GTA are 25086564 or 25086563. The 64 part number works with the high output which I think is the 350 since that is what my buddy has. They will have the 63 part number left. I will see if they7 have more.
I also have found other places that repair digitals on the web.
www.gmspeedometerrepair.com
www.dashusa.com
www.instrumentclusters.com
www.dashusa.com
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
I know we seem to be anti-dealer on these pages, but your local gm dealer usually has access to reman clusters or can have yours sent out and repaired. The repair facility we use does as medic suggested, on an exchange basis, unless they don't have any on the floor in which case you send yours in and they will repair it. Even if the dealer marks up the work, you should be able to get it done for between $250-350.00. If you can find out who they use, sometimes you can bypass the dealer and save a few bucks. Many dealers don't mind giving out that info if it means they don't have to hassle with an older car like ours. Plus the repair/exchange facilities should warrant their work for at least 90 days and some will warranty it for a year.
digital dash
Thank you QuickMedic and Vaneat-91RS for your assistance. Good info. The dash in my GTA is working for now but has spells during which some features do not function. I'm presently suspecting a loose connection somewhere. It's always something but I will prevail. Another Phoenix!!! Thanks again, Dave
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
Re: digital dash help
did anyone try to repair the trip/odometer?
Have the fading out problem!
I will start to look into the problem to find what component that fail's. But maybe someone alredy know?
I recently used Technicar in Tampa Florida to get another digital dash for someone. All the dealers in my area use them. $200 for any repairs with a 1 year warranty.
Technicar Inc.
450 Commerce Blvd, Oldsmar FL 34677-2808, United States
(813)855-0022, (813)854-5098 fax
http://www.techni-car.com/index.php
Technicar Inc.
