manual shifter knob
Old Dec 26, 2005 | 04:51 PM
zammer's Avatar
Car: 1988 T/A GTA
Transmission: 5spd
manual shifter ****
Is there a trick to removing the gear shift **** on a manual trans. in an '88 GTA? I figured it would be better to ask before I broke it.
thanks
Old Dec 26, 2005 | 04:53 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Righty tighty, lefty loosey
Old Dec 26, 2005 | 05:05 PM
zammer's Avatar
Car: 1988 T/A GTA
Transmission: 5spd
I kept going lefty loosy but it wasn't coming off, at least it didn't seem like it was.
thanks
Old Dec 26, 2005 | 05:29 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
The cover sometimes slips on the threaded ball inside the handle. Just gotta grip it tighter, best you can. Factory really muscles them on if its never been off.
Old Dec 26, 2005 | 05:50 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
If you're tossing your factory ****, a pipe wrench works keen.....
Seriously, squeeze like a ***** and turn counterclockwise. I've seen
them so tight, that you had to hold onto the shaft with a vise grip to keep
them from turning together, which is not a good thing since the shaft is
hollow.....
Old Dec 26, 2005 | 06:49 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
one trick is to use a die grinder. are you getting a new one or something? if so i wouldnt worry about it staying in good shape and just thrashing it till its off.
Old Dec 27, 2005 | 07:57 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
hollow.....
Old Dec 28, 2005 | 02:35 AM
JBert's Avatar
Car: Looking
now, if you really cant get it off- just take the whole thing out and toss in a short throw
Pac J
May 17, 2020 10:44 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
ronscott80
Oct 13, 2015 12:26 AM
bjpotter
Oct 2, 2015 09:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
