new idea..reverse hood and removable front clip
Old Jan 1, 2006 | 11:01 AM
Phoenix8936's Avatar
ok with getting back into the trans am scene now..i have gotten an idea in my head..
first is to do a reverse opening hood..which im sure i wouldnt be the first to do..and i know there are kits out there..but was wondering if anyone here has done this and what the opinions are on this all together..??
second is that to make a fully removable front clip..fenders front bumper and hood all in one piece and easily removed..this will be a major task and will be tough if even possible..but again anyone ever done it to a 3rd gen?
my reasone for the second idea is to make it easier to tune the suspension and what not since the car i will be buying will be made into a track car persay..
any help, ideas or suggestions would be greatly appreciated..thanks
Old Jan 1, 2006 | 12:31 PM
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
For the second idea I think it is fully possable just use a series of pins with those spring clip things so it would be secure but when adjustment is needed just pull the pins and pull front clip off.
Kyle
Old Jan 1, 2006 | 11:21 PM
Pocket's Avatar
Car: 91 Trans Am
Buy a 1 piece fiberglass front clip, 1/3 the weight, and normally comes with the hardware to make it open like you described or like a corvette front clip does, depending on the company
If I were you I wouldnt do a pin on style front flip unless it was strickly a drag car.
Old Jan 1, 2006 | 11:23 PM
True_bird's Avatar
Car: 1985 Firebird
Well he did say it was stricktly a race car...
Kyle
Old Jan 2, 2006 | 08:48 AM
Kyle
well to be truthfull i said track car..like in local road racing..not so much drag racing..
Old Jan 2, 2006 | 08:49 AM
do you know if a good company..?
Old Jan 2, 2006 | 02:43 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
harwood makes them but the fenders need to be trimmed about 4 inches to match factory specs. I think the harwoods are made for pro-mod cars, so it's got stretched fenders.
Old Jan 2, 2006 | 06:55 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
reverse open hood. Very old photo. Done this back in 1999.
Attached Thumbnails new idea..reverse hood and removable front clip-83z.jpg.jpg
Old Jan 3, 2006 | 02:59 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Do you have any more pictures of that hood/hinges?
Old Jan 3, 2006 | 03:52 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have read where people use the hinges from an 88? thru 1991 Buick LeSabre or Park Ave.
John
Old Jan 3, 2006 | 03:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
VFN fiberglass also makes the 1 piece front clip.
Old Jan 3, 2006 | 06:09 PM
Engine: 400 and 350
John
Thats what I did. Took a weekend to figure out but it wasn't to bad to do. The hinges are now just laying on the floor.
Old Jan 3, 2006 | 06:31 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/techbb2/sho...threadid=68549
Theres all the companys, well a right many of em
Look for the 1 piece front clip
And if your really feeling frisky you can fiberglass your own
Old Jan 3, 2006 | 09:05 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
What year exactly did you grab it off of? Are those the cars that the hood slides forward a bit and the bends forward?
Old Jan 4, 2006 | 08:14 AM
okfoz's Avatar
yes, the front pops up, then you slide it forward to release it from the rear clips, and then it rocks forward.
Not sure if it will work on a Firebird because of the nose, but it works great on a Camaro.
John
Old Jan 6, 2006 | 11:35 AM
Engine: 400 and 350
OKFOZ got it right on.
Old Jan 6, 2006 | 06:10 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
John
I have a feeling it could work if it was mounted in between the headlights and the connecting rods between the two hinges were shortened. It'd be easiest to ditch the toolbench that sits in front of the hood latch and make brackets that stick up from the bumper...
Old Jan 9, 2006 | 07:57 AM
okfoz's Avatar
I would think that you should reinforce the area around the headlights, as there is little structure on our hoods in that area. Would not want ot to buckle when you lifted it.
John
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
