F Body Roof Console
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
F Body Roof Console
I am Installing a Roof Console in my 3RD Gen. Formula . I was just wondering how I might Locate UNDER the Headliner the 4 MOUNTING Holes for the 4 Console Mounting Screws ? Anyone happen to Know how I could do this WITHOUT taking the Headliner and Foam Backing Down from the Roof ? Any Advice would be welcome
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I made a cardboard template from the overhead console and mocked it up by using the two rear screws (the two that hold the dome light in place). I cut X's in the material, not only so that I could make the necessary cuts but also so I could tuck the material in above the headliner. Go slow. Cut small and go larger as needed.
Here are a couple of links that may prove useful:
https://www.thirdgen.org/newdesign/t...dconsole.shtml
https://www.thirdgen.org/techbb2/sho...hreadid=226910
JamesC
JamesC
F Body Roof Console
My main concern is locating the 4 Holes under the headliner . Are these Holes Already there from the Factory even on those Cars that did not come with a console ? I have ALL the Hardware to do the Job , and can wire it up easily . But I think and Hope this could be Done WITHOUT removing the Headliner and Foam backing All the way off the Roof . Your template Idea sounds like a Good one , but How DEEP will I have to go into the Headliner before I have enough room to get the Mounting Screws to CATCH in the Pre Drilled Holes ? Any more advice would be Welcome . And if you haven't Noticed , I have a HARDTOP Car , and a HARDTOP Roof Console .
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
Did the same to my 1988 Formula 350..had to cut the liner and if you have the PROPER bolts for the o/head consul; the threaded holes are there already.....did a lot of sweating until I found them...but do the cardboard template as suggested above..did it the same way...
F Body Roof Console
Thanks MidNiteRider , I will try just that !
And Thanks Again for your Help JamesC . I will Post later when I have it installed and Maybe Learn some more Tips on how to make this Installation Easier to do . MARK.......
Roof Console -3RD Gen .
Well , I finally Installed the Roof Console . What I noticed about this Procedure is this... You can Install it With the Headliner On , But if your Headliner is Old , Brittle and Sagging , you will wind up Ripping the Chit out of it ! LoL . I also had a problem with the Ground Wire positioned on the Front End of the Console . The Screw Hole for it was Too Large for the Factory Screws I was trying to use to Ground it to the Roof . So I ran the Gound wire to the dome Light and Grounded it to one of the screws that Holds the dome light in place . It worked Fine when I gave it Power . I noticed at Night , with a friend who smokes in the Back Seat , that the Map Light swivels Back to Eluminate the Rear Center Console Ashtray . And it is Dim enough to leave On while driving .
P.S. I have a MINT CAMARO Flashlight in Good Working Condition in this Console , but I have a Formula . Anybody wanna Trade me a PONTIAC Flashlight in GOOD WORKING Condition for my CAMARO Flashlight ? An EVEN Swap maybe ? Let me Know Gentlemen...
Mein Got !
Originally posted by JamesC
You allow SMOKING in your car, Mein?
JamesC
JamesC
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Roof Console -3RD Gen .
Console Flashlight
These Flashlights tend to Corrode at the Battery Contacts and the Plastic Breaks easily . The One I have is in Very Good Condition considering it is 18 years Old . The Pontiac Flashlight was in many Trans Ams in the 80's Years , and should be more Numerous . They are out there for around 50 Bucks if you can Locate a seller for one .
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
