IROC Decal installation help
Old Feb 3, 2006 | 01:08 PM
jsrailrd's Avatar
Car: 88 IROC
Engine: 5.0 TPI, BORED, HYPER PISTONS, CAM
Transmission: auto
Does anyone know of or know where to find the factory spec for positioning the IROC decals on the doors. I have heard the rear of the door handle is the starting point but can't find a height measurement. Trying to finish a 2 Yr resto.
Old Feb 4, 2006 | 07:25 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I don't know where you would find that info "writtten"....I would get a look at somebody ele's car ....if you need to take a measurement from that...........
Old Feb 4, 2006 | 07:53 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: IROC Decal installation help
I have seen them at the front of the doors and the rear of the doors Maybe they are different from 85-87
Old Feb 4, 2006 | 10:32 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Re: Re: IROC Decal installation help
Not positive but I was told if the decal was on the front of the door it has a 305 and if its on the back of the door it has a 350.
Old Feb 4, 2006 | 10:57 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
if it's on the front of the door it's 85-87 if it's on the rear of the door it's 88-90 i'll look and see if i can find the information again, but it was written somewhere where to start the decal .
Old Feb 4, 2006 | 11:01 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
That makes sense
Old Feb 5, 2006 | 10:14 AM
Car: 94 25th TA
Engine: 355LT1
When I bought my 88 Iroc-z I'm almost positive it had the original paint and decals still on it and the sticker was on the front of the door????
Old Feb 5, 2006 | 03:42 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
alright found them for 85-87
For 1985 - 1987, the correct dimensions are:
Driver's
Horizontal: 6-3/8" from the front leading edge of the door to the lower left corner of the "I".
Vertical: 2-5/8" from the rocker molding to the same corner of the "I".
Passenger's
The same dimensions apply but to the lower right corner of the "Z".
I still have to find them for the 88-90
Old Feb 7, 2006 | 06:57 PM
net_coma's Avatar
I can measure my 88, tomorrow when there is some light.
Old Feb 8, 2006 | 11:04 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
My 89 has the sticker on the rear, if this helps, and it's original paint.
Old Feb 8, 2006 | 12:42 PM
jsrailrd's Avatar
Car: 88 IROC
Transmission: auto
From what I've read, 88 - 90 were all on the rear of the door. I really do appreciate everyones input, Thanks
Old Feb 8, 2006 | 08:46 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Measured the decals on my 88 at the rear of the door, four inches from the rear of the door to the bottom corner of the decal, 5 7/8" to the bottom of the decal to the bottom of the door to the bottom edge of the plastic cladding. Might have been 6 inches to the bottom of the steel door? Hope this helps.
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
