Hatch struts... alternatives?
Old Feb 16, 2006 | 07:25 AM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
My hatch struts, or gas dampeners or whatever they are called are old and useless, been for a very long time.
I really don't want to buy new ones because they'll be as ****ty in a few years, probably because of the cool winters here. Are there any other systems than these struts for cars?
There's got to be something?
Old Feb 16, 2006 | 07:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
vice grips and a rag.
There's also a tool specifically made to keep struts up, but it's just a glorified c-clamp.
Unless your car is a clapped out POS, buy new struts.
Old Feb 16, 2006 | 09:42 AM
Pocket's Avatar
Car: 91 Trans Am
You forgot the almighty stick
A new set of struts are $60 from O'Reileys... lasting 2-10 years, I dont see this as a big deal
Old Feb 16, 2006 | 09:53 AM
stitchop's Avatar
Car: 91 firebird
I still have the original struts on mine after 15 years, still nice and tight. If they ever go bad, I will buy new ones, if they last half as long as the stock ones, I will be very happy.
Old Feb 16, 2006 | 10:02 AM
We're looking at the shorter end here given the climate. I think it's wastefull and inefficient to change struts every few years so I was looking for something more effective.
I do know that when a buddy of mine had this old Volvo 142 the hood opened and stayed open and no struts where used. I wonder what kinda system that was.
I guess I could change but I don't wanna
Old Feb 16, 2006 | 12:32 PM
stitchop's Avatar
Car: 91 firebird
Here in Arkansas we have a great way to hold the hood and hatch open after the struts give out: We keep a couple of broom handles under the deck on the trailer.
Old Feb 16, 2006 | 01:13 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
mine only work when its above about 75*, so i got 3 zip ties and got them as tight as possible on each side, and slide them up to hold the hatch No sticks, little work when needed.
Old Feb 16, 2006 | 02:14 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I put a prop rod setup from the junk yard on mine
Works like a charm.
Course till the weight of the glass bent the damn prop rod.
Shatter shatter it went
U know I'm sure I had someone going there :-) lol
Get quality hatch struts, no easy alternatives that I know of.
later
Jeremy
Old Feb 16, 2006 | 02:19 PM
Pocket's Avatar
Car: 91 Trans Am
Sure hope you dont put off changing shocks/struts/any other pressurised gas cylinder because its "wasteful and inefficient" to do so on a schedule
Most cars use spring pressure to keep trucks/hoods open. GL fabbing a system for that with the hatch... You can put a prop rod under there, but without struts the hatch is crazy heavy. GM put struts in there instead of all these other possibilites for a reason: they are more cost effective and practical
Old Feb 16, 2006 | 02:37 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I spent $45 or $50 on new struts front and rear a year or so ago. Well worth it after spending 2 years driving around with a break-down scavanged weed-eater handle in the back to keep stuff open.
I had forgotten what my car looked like with the hood AND the hatch open at the same time.
Old Feb 16, 2006 | 03:03 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
I have some stuts id sell you if you want em, there almost brand new, i pulled em from a car i bought and parted..... PM me for more details, i dont want much for em' It's better than buying new ones.....
Old Feb 16, 2006 | 08:22 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
By the way guys any one know where to get the best ones . I got some at pepboy's a few years back and they didn't last very long. I thought i heard that the one's from napa are ok. Any input?
Old Feb 17, 2006 | 01:28 PM
Pocket's Avatar
Car: 91 Trans Am
Best is a horribly overused word in here
To answer your question thou, the concept you get what you pay for is pretty self explanitory
Youll sell your kids to the dealership but OEM is proven the be good for 10+ years
Local parts stores are $40-100 per set and seem to last 2-5 years
And finally your discount auto that might work for a weekend
Old Feb 17, 2006 | 04:17 PM
3.8TransAM's Avatar
Heres something else to consider.
They have several versions of the struts.
W/without wiper, spoiler, etc.
Make sure you get the right strut in the first place.
Spoiler adds weight in a hurry.
I have had great luck with the Armstrong tagged brand from CarQuest stores.
later
Jeremy
Old Feb 17, 2006 | 04:24 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Get a Lexan replacement for your hatch glass and your problem is solved. Lightweight so its less stress on the struts.
Old Feb 18, 2006 | 10:37 AM
Car: 1990 trans am
Engine: 350 tpi
Car: 1990 trans am
Engine: 350 tpi
Thats funny i bought my car new in 1990 and the struts in the hatch and hood were shot in 1995, so oem is not the best imo. Just iooking to get something decent and not get riped off Any oppinions on where to look for something of quality? (not used this is not a part i would recomend getting used.)
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
