How to make an ASCD RA1 Hood functional?
Old Mar 10, 2006 | 11:54 AM
kaylin4u's Avatar
I recently purchased an ASCD Ram Air 1 Hood. I know it wasn't designed to be functional, but I was wondering if anybody were able to modify the hood to allow the air come in (kinda like a cold air induction) and possibly make it a semi-fuctional? If so, does anyone have pics of the modification?
Old Mar 10, 2006 | 02:05 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
there used to be an air box available from ASCD. anyone knoe where he can find it.
Old Mar 10, 2006 | 07:51 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Never was an air box for the RA1. There's one for the RAII that can be modified to work.
Kevin D.
Old Mar 10, 2006 | 10:59 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
No I remember an airbox for the RA1 also, but it wasnt ASCD
Old Mar 10, 2006 | 11:29 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are you thinking of the one for the suncoast creations hood with the nostrils at the very front of the hood?
Old Mar 11, 2006 | 07:01 AM
shr00m's Avatar
Believe me, I've been following the ASCD RA1 since it came out. There was never an air-box for it, from ASCD or others. Iansane is right, Suncoast had a similar hood that didn't look as good that did have an air-box, but it won't fit the ASCD one. The fact that the ASCD isn't cut and has a rain/air deflector right behind the nostrils makes it real fun to even make another box work.
Kevin D.
Old Mar 11, 2006 | 08:20 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I thought the Suncoast hood was a nicer hood than the ASCD RA I, and even more so since it was fucntional. Unfortunately by the time I was in the market for a hood the Suncoast one was discontinued.
Now it would be the RA II or nothing, because my opinion is why put on a ram air hood if you can't make t functional?
Old Mar 11, 2006 | 09:09 AM
shr00m's Avatar
Exactly my feelings. I never said you couldn't make it functional, you just have to make stuff...
Kevin D.
Attached Thumbnails How to make an ASCD RA1 Hood functional?-ls1-ram-air-finsihed
Old Mar 11, 2006 | 09:10 AM
shr00m's Avatar
Hood cut:
Old Mar 11, 2006 | 09:59 AM
kaylin4u's Avatar
That is exactly what I'm looking for. Somebody who as cut the ASCD Ram Air 1 Hood. I'm hoping you can get more pics of that cut you made. I don't want to hurt anything else on my $500 hood (if you know what I mean).
Thanks so much!
Old Mar 11, 2006 | 10:01 AM
kaylin4u's Avatar
BTW, where did you get the parts to make that Ram Air Filter box?
Old Mar 11, 2006 | 11:29 AM
shr00m's Avatar
Thanks so much!
Request granted.. It's pretty easy to tell where the layers are not touching. I went a little in from where the top curves down on each side, that got my width. I then went as low as I could go before hitting the bottom curve. I did the same on the top, leaving it a straight line from side to side. This gives you a nice rectangle. Just some painters tape to keep the lines clear, then a reinforced cutoff wheel on the dremel. It really didn't take more then 10 minutes (hood was not on the car at the time).
You can see both sides of the 'rain deflector'. You can leave it, but it is in the way. It's only attached on the sides and is real loose in the middle. It's a rough piece of fiberglass, all you need to do is cut the sides and it will pull/break off of them.
I should have cut it before paint, but oh well. You can't really see in there much without stretching and a flash.
As far as the airbox, you can read what I did here: box thread
Since your going to a stock motor, you won't have to do nearly as much as I did. Just remember, the stock mounting tabs on the RA2 box puts it too far forward to do a whole lot.
Kevin D.
Attached Thumbnails How to make an ASCD RA1 Hood functional?-cut-hood-003.jpg
Old Mar 11, 2006 | 12:52 PM
kaylin4u's Avatar
This engine is going to have the Holley Stealth Ram. So yeah, I might need to make a box like you did.
Thanks sooooo much!!!!!
I'll get started on the hood within the next week or two. The picture shows enough.
Old Mar 11, 2006 | 01:28 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Shroom, is there a significant amount of rain where you are? I've always kind liked that style air flow. RA1 w/ a box going straight into the engine but I've always been kind of apprehensive about te engine sucking water. I realize it's not driving yet but does that worry you at all?
Old Mar 11, 2006 | 01:37 PM
shr00m's Avatar
A good bit of rain, but the car isn't going to be in it. If I ever get caught, there really shouldn't be too much rain getting in. It would have to go through the small holes, 'float' high enough to get over the lip, get past the K&N that's designed to be rinsed, and then be enough to not evaporate through the intake.
You could probably get a foam strip like I have sealing the back of the air-box, and just shove that into the hole. The engine would still get plenty of air from elsewhere, but no direct path for water.
Kevin D.
Old Mar 13, 2006 | 04:13 PM
kaylin4u's Avatar
By the way, shr00m, how wide is that cut? I figured that I can cut at the curves toward the top and bottom like you said, but I don't know how wide your cut was?
Old Mar 13, 2006 | 05:51 PM
shr00m's Avatar
20", as wide as my filter.
Kevin D.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
