how to open cowl hood??
Old Mar 13, 2006 | 08:43 AM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Well i bought a cowl hood from bruce on hawks third gen, And cant find were to put the spring. Has any one come across this problem ? Thanks eric
Old Mar 13, 2006 | 02:12 PM
JTZ28's Avatar
sounds like u bought a lift off hood! you'll have to pin it
if thats the case
Old Mar 13, 2006 | 10:38 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
if thats the case
Not necessarily. Some manufacturers don't drill the holes in the fiberglass for the spring mounts. My Harwood came with holes (and little brackets) for the spring, but they were in the wrong place. I had those holes filled when the car was painted and drilled new ones.
Old Mar 14, 2006 | 10:55 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
It is a bolt on hood, i am on a little head ach with the spring. it doesnt have anything for the spring to mount on. Anything? Thanks for replying guys -Eric
Old Mar 14, 2006 | 11:27 AM
JTZ28's Avatar
i would call bruce at hawks and ask him .
Old Mar 14, 2006 | 08:42 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
I have called but he says he is trying the best to find out some info, or pics. But thats why i am asking you guys. Thanks
Old Mar 15, 2006 | 12:56 AM
JTZ28's Avatar
my buddy sez that you have to pin the front
Old Mar 26, 2006 | 10:21 PM
Justin86camaro's Avatar
Car: 86 Camaro
Engine: 350, aluminum heads, carb
Transmission: TH-700R4
Axle/Gears: 7.5 10 bolt, 3.42:1
spring
i have one and don't need the spring just pull the latch then go and grab the hood in the headlight pocket and lift up until the latch catches it then pull the lever to raise the hood.
Old Mar 27, 2006 | 11:34 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
What is the reson to pin it, still cant open the hood?
Hotrodboba400
Dec 10, 2019 07:07 PM
Randomtask2
Sep 7, 2015 05:06 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
