Gas springs for the hood
Old Mar 21, 2006 | 05:49 PM
305TransAm-84's Avatar
Car: Pontiac TransAm -84
Transmission: TH700R4
The gas springs for the engine hood is worn out. They cant keep up the hood (was worn out when I bougth the car).
The gas springs alone keep the hood upright (I mean, there isnt any other locking-mechanism here?), am I right??
It is easier to find an aftermarket gas springs around here, so I need spec/info about the springs. How many Newton are they? (Newton is marked with an "N" after the number. Example: 350N)
A blue tape on top of spring isnt possible to read anymore (if spec has been stamped there)
Old Mar 21, 2006 | 06:44 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Correct.
Sorry, no numbers visible on the blue sticker on my struts either. No other markings on them that I can see. I need new ones for both cars!
Old Mar 21, 2006 | 06:50 PM
Thanks.
I hope anybody knows how many Newton, or have new struts they can take a look at...
Old Mar 21, 2006 | 07:05 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Just go into the parts store and look at the book....look up your car...get the part number, and pull em off the shelf...thats what I did...frankly, I couldnt care less how many newtons they were rated for...I got the ones listed for my car, and they worked perfectly
Old Mar 21, 2006 | 07:25 PM
bru333's Avatar
Car: 1987 Camaro SC
The "Strong Arm" brand part number is 4422, if that helps you any.
Old Mar 21, 2006 | 07:43 PM
Thanks, but here in Norway, Europe a US/GM partshop isnt easy available. They maybe have original struts at the mainoffice, but they are about 400 miles from here.
Therefore, I would try to locate struts at a local universal carparts-shop, but then I have to know the pressure i Newton. But the SIZE of the strut is easy to compare
Old Mar 21, 2006 | 07:50 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Why not go to a web site like napaonline.com and just order the right ones for you.. Just have them shipped to you..
Old Mar 21, 2006 | 08:03 PM
project86ta's Avatar
Car: 86 TA
Engine: 305 carb
Transmission: 700 R4
Axle/Gears: Not Sure
I have a set of hood struts I picked up from the parts store the other day but they have no markings on them in newtons or psi. I can however tell you that I can't even budge it by hand so it's going to have to be pretty stout.
Old Mar 21, 2006 | 08:14 PM
Uhmm....by sending them from US to Europe tends to multiply the price by 10 times
The local partshop has struts for European car-hoods for 20$ each. They are marked with pressure-value all of them.http://www.biltema.no
Anyway, I searched www.napaonline.com, but they had only door-hinges in that part-category.
Old Mar 21, 2006 | 08:18 PM
madathlon's Avatar
napaonline was just a thought.. I know U might also find a buddie here and see if maybe someone can get it in the states and ship them to U if you cover the bill.. I have done this for friends of mine on the FTE boards.
Old Mar 21, 2006 | 08:19 PM
If you cant move it by hand then the pressure probably is at least 300N on it. But, first time movement of a new gas strut is always harder than later.....
Pity that it had no markings....
Old Mar 21, 2006 | 08:42 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Just as an FYI...I recently pulled my 91 z28 into the shop for an engine swap.
9 year old struts, wouldnt hold up the hood, and I still couldnt move em by hand.
Dunno if it helps any, but the GM part numbers are #GM-C141 R or GM-C142 L, hawks thirdgen has em...here:
http://www.hawksthirdgenparts.com/in...il?v=1&pid=170
Old Mar 22, 2006 | 02:35 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
http://www.top-downsolutions.com/pro...products_id=92
Old Mar 22, 2006 | 02:57 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I need a new set at well.. for both the front and the back... Going to head into napa tommorrow... will get some specs on them while i am there looking at them.
Old Mar 24, 2006 | 11:36 AM
Thanks everyone.
If Angelis check the new struts if they have number, that would be great.
If not, I will try to figure out the right strut at the local shop by "try and return-metod".
By the way, the struts at the back are bad too...
Old Jul 4, 2015 | 01:30 AM
JACKO's Avatar
Re: Gas springs for the hood & hatch
I'm from OZ so parts hard to get. Needing hood and hatch struts re gassed. 91 firebird. need to know PSI or NM so I can get them done, help would be greatly appreciated.
Old Jul 4, 2015 | 04:45 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I would think that who ever you find that rebuilds these things would know how much pressure to put into them.
http://www.strutwise.com/
Old Jul 4, 2015 | 06:20 AM
Saxondale's Avatar
Car: 84 Z
My blue stickered aftermarket struts have the 4422 number and made in usa stamp, but no brand name or psi.
Old Jul 4, 2015 | 07:31 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I've never seen a PSI or newton meter number on any struts or replacement struts...
If someone grabs a new one, push it down on a scale and record the number then convert it into that goofy newton meter number..
Old Jul 4, 2015 | 04:00 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
FWIW, they're made/distributed by AMS Automotive. No pressure specs.
Old Jul 8, 2015 | 11:26 AM
Hawke's Avatar
Car: 1986 Trans Am w/WS6
Engine: 305 (5.0) TPI
I also need mine replaced. I found them on Rock Auto. Going to give the AC Delco brand a try.
Old Jul 9, 2015 | 04:21 AM
TTOP350's Avatar
Stablius or something like that is a better brand. The delcos won't last very long. This is one time i"d say, don't use gm/delco parts.
Old Jul 10, 2015 | 03:03 AM
JACKO's Avatar
yeah heard Rock Auto do good, not sure if they ship to OZ will look into it
Old Jul 10, 2015 | 07:51 AM
steveo346's Avatar
Car: 91 Camaro z28, 1968 c10
You guys are looking for some fairly priced struts that will hold the hood up and the rear hatch without any issue, well look no further! I found a company on ebay called StrongArm. I bought their struts for my hood and hatch and they work freaking great!
and these were the hatch struts. Now I just push the button on my center console for my hatch release, and it pops open on its own, just like in 1991! Highly recommend!
Old Jul 10, 2015 | 09:08 PM
TTOP350's Avatar
Yup, that's what new parts should do.
Old Jul 11, 2015 | 12:36 AM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Honestly I'd rather not have the hatch pop open all the way. It's only glass you know. Excessive force on that glass could cause it to shatter. The rear hatch glass isn't laminated like the front windshield is it? It's just tempered right?
Old Jul 11, 2015 | 01:02 AM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
just ordered off ebay gm replacement and work fine for many years
Old Oct 9, 2017 | 03:05 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Ya, ya I know. I'm a dbag for bringing up a 2 year post :/
But just wanted to say that I just replaced my BARELY USED 4422 mighty lift hood lifts with SACHS brand.
The 4422's where on my 82 t/a with the bulge hood, hardly used and only lasted a few years before the hood started to drop a few inches was it was up
Just a courtesy heads up NOT to waste your money on the mighty lift 4422 hood shocks
Dave
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
johanlindgren
Aug 16, 2015 12:16 AM
