Going Nuts with Gauge pod!
Old Apr 7, 2006 | 03:21 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I cannot for the life of my figure out where the bottom release is on the gauge pod (stock). I have removed the faceplate, clear plastic protector, and metal pod and am down to where you how your electrical connections for your gauges. I cannot for the life of my figure out how to get behind/disconnect it. The top half is free and loose but the bottom half has some odd clips but when I press them in it seems to not free anything up...
Old Apr 7, 2006 | 03:30 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Is it mechanical or electric?
Old Apr 7, 2006 | 03:33 PM
r0nin89's Avatar
/sigh, electric. Only asuming because all the guages plug into ports
Old Apr 7, 2006 | 03:35 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
what year?
Old Apr 7, 2006 | 03:36 PM
r0nin89's Avatar
88 rs, Its not the long pod its the upside down U shaped one all behind the wheel.
Old Apr 7, 2006 | 03:41 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
There are 2 10MM nuts holding it in on the bottom. These nuts are located where the bulbs are, the ones that light up the seat belt, choke, check engine etc. Once you remove these you have to remove the speedotomer cable from the speedo. This can be done several ways but I find it easiest to lie on the drivers floor, pull the fuse box down, stick your arm up behind the dash and unclip it. Once you get the 2 nuts off you will see how the speedo cable is attached. Try doing a search and I am sure someone has posted pictures on the removal.
Old Apr 7, 2006 | 03:44 PM
r0nin89's Avatar
thank you very much going to do it now.
Old Apr 7, 2006 | 03:45 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Old Apr 7, 2006 | 04:05 PM
r0nin89's Avatar
Yay thank you so much. I got it off and looks like theres plenty of space for gauges! I guess I am going to have to do gauges before I drop the car only because theres no way I am putting this back together and then taking it apart again
Old Apr 7, 2006 | 04:11 PM
r0nin89's Avatar
OK where should I run my new guage wires through?
Old Apr 7, 2006 | 05:12 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have no idea, I have never done it before
apie2546
Oct 16, 2016 02:24 PM
gord327
Sep 29, 2015 10:18 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
3.8TransAM
Sep 27, 2015 08:37 PM
