Carpet Replacement
Old Apr 9, 2006 | 09:36 AM
Destro's Avatar
Car: 1992 Camaro RS
Engine: L03 5.0 V8 TBI
Transmission: OEM Automatic
Carpet Replacement
Can anyone who has change the interior, tell me who has the best fitting?
Old Apr 9, 2006 | 10:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There aren't a lot of different manufacturers making molded carpet. ACC and ACS are the two biggest. Both fit well, but will need some trimming on your part. The big issue is that the ACC stuff fades badly, and the overall quality just isn't as good as the ACS. Unfortunately, 99% of the retailers carry ACC.
For more info on the ACS carpet, give me a PM.
Old Apr 9, 2006 | 11:37 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
AMEN brother Jim85IROC, I also just installed the ACS carpet in my camaro and am happy I did. It has a denser thread count and is just a much nicer feeling carpet. I got mine online at JCWhitney.com. ACS gets the thumbs up from me.
Old Apr 9, 2006 | 12:11 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I bought my acs carpet from jim and it fit surprisingly well for aftermarket. Just lay the old one on top of the new one, rough cut the openings out and about 10 minutes of trimming and its done.
Old Apr 9, 2006 | 03:09 PM
mpayne's Avatar
I'm putting new carpet in my camaro and was wondering how you guys got the carpet over the rod on the rear of the tranny tunnel that holds the center of the rear fold down seats so that the holes are in towards the middle as far as possible.
Old Apr 9, 2006 | 10:09 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Do any companys send out sample pieces of carpet. My doner car has light gray carpet and I was wanting to go a bit darker when I swap it over to another.
Old Apr 9, 2006 | 10:27 PM
mpayne's Avatar
I can't remember if my carpet is acc or acs but whoever it was sent 4 different samples of light grey so I could match it up with my original. Just call them up and tell them what you want to do and they'll send samples out.
Old Apr 10, 2006 | 08:22 AM
Jim85IROC's Avatar
Send me a PM and I can get some samples out to you. Another nice thing about the ACS carpet is that you get a good sized sample so you can actually see the color, instead of the 1" piece that ACC gives you.
Old Apr 10, 2006 | 09:28 AM
kammi10's Avatar
Car: 1989 camaro
jim how much does a full carpet kit cost for front and back? that is from you of course
Old Apr 10, 2006 | 11:18 AM
Jim85IROC's Avatar
PM me and we can discuss it. I don't want to use the forum for business issues.
Old Apr 10, 2006 | 04:17 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I have purchased my last few interior replacement materials from Auto Carpet - Car carpet - Automotive Carpet
Very good quality materials.
Old Apr 11, 2006 | 07:54 AM
LETZ RUN's Avatar
Car: 1986 ****** Camaro
Engine: 355
Transmission: th350
Axle/Gears: 3.42 10 bolt - temporary
do you have any carpet that i guess would be labeled "race carpet".. im meaning covering the whole trans tunnel for no console, and no gap in the back because there is no back seat, etc? If not I guess im gonna have to use regular carpet and cut/adhesive/mold my own and thats gonna suck.
Old Apr 11, 2006 | 03:25 PM
Pocket's Avatar
Car: 91 Trans Am
Most companies wont pre-cut it
My A1Auto carpet had a very small shifter hole (Had to enlarge it some) and that was it
Came several inches bigger for a perfect fit
I wrote a review on A1Auto in the review section about it
Old Apr 21, 2006 | 07:38 AM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
carpet
when i got my carpet, i had to cut holes for all the bolts for the console and whatnot. the easiest way i found to do this is to lay the new carpet over the old carpet (of course this only works if you have the old carpet) and just trace and cut. as far as getting it under the seats, you could either pull it through or just take the back off and fit it in.
Old Apr 21, 2006 | 07:54 AM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
sent you a PM Jim. Thanks!
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
