Ignition Cylinder Removal
Old Apr 10, 2006 | 05:05 PM
LETZ RUN's Avatar
Car: 1986 ****** Camaro
Engine: 355
Transmission: th350
Axle/Gears: 3.42 10 bolt - temporary
I purchased a steering column from ebay. It said it came with a key although it didnt. It didnt have a steering wheel on it. I got a couple of the rings off and the plastic thing on top. Its to the metal flat plate thing. I think there is a tiny ring holding that on but its like super duper hard to get off. Is that what I need to take off to get it out? If it helps I think it was from an 83 blerinetta. I dont to put an ignition switch back in there, so breaking it is fine, its already mangled up from me breaking it. It to turn now, but I want to get it completely out so it doesnt accidently lock on me or something while im driving.
Old Apr 10, 2006 | 05:58 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
its not that hard once U remove the steeing Lock right. than look by where the lock would be.. U should see a screw thats point right at the bottem of it.. ( Should be Phillips or #15 tork ) And remove it.. than remove old key and istall new keyswitch
Old Apr 10, 2006 | 06:00 PM
LETZ RUN's Avatar
Engine: 355
Transmission: th350
what do you mean by the steering lock? ill take a pic in a few when i get home to show how it currently is.
Old Apr 10, 2006 | 06:04 PM
madathlon's Avatar
when U pull the steering wheel. ( I know urs is missing ) there a ring with "U" shape teeth in it.. thats the steering wheel loch that hold the steering still so no one can steal it..
Old Apr 10, 2006 | 07:04 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you forgot to say that he needs a tool to push that lock ring down so he can get the snap ring off. that plate has a strong spring under it. tool is required to be safe!
Old Apr 10, 2006 | 07:08 PM
madathlon's Avatar
Very true..
Old Apr 10, 2006 | 07:16 PM
LETZ RUN's Avatar
Engine: 355
Transmission: th350
here are the pix.. you can see how much of the cylinder we got out by just mangling it.. lol.. right way i know. like i said i dont need to put one back in there. also a pic of the top. i think there is a ring there you just gotta push down on the metal plate, what tool can i use? any ideas?
Attached Thumbnails Ignition Cylinder Removal-steeringcolumn.jpg   Ignition Cylinder Removal-steeringcolumn-002.jpg
Old Apr 10, 2006 | 11:26 PM
@ZZKKER's Avatar
you can rent one. its the steering lock remover. then use a pick to remove the snap ring when it has the spring tension off of the lock plate.
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
