Problems opening hood. (Not a latch problem)
Old Apr 23, 2006 | 08:58 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I just put the hood back on my 91. For some reason, when I pull the hood up to open it, the back of the hood doesnt raise up. I have to wiggle the hood to get the back up before I can continue raising the hood. If I just keep raising it up... I think I will probably bend the hood at the hinge area. What Can I do? I already have the bump stops adjusted perfectly to line the hood up with the fenders. Any thoughts?
Thanks in Advance,
Mark B
Old Apr 23, 2006 | 11:04 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
that's a common problem due to how heavy and long our hoods are. I'm guessing that your hood struts are shot or atleast not very good. New struts will make the hood rise by itself for the most part and you'll avoid the problem you're describing.
Old Apr 23, 2006 | 11:29 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You may still need to adjust the Rr bump stops a little more.There is also one in the center of the hood.
Old Apr 23, 2006 | 11:45 AM
JerseyMark's Avatar
Engine: 96 LT1
Hood shocks fixed it. The shocks that were on there were pretty new... But were the cheapies that you can find on E-Bay. I went to AutoZone and picked up a set. Presto!!! I guess you get what you pay for.
Old Apr 23, 2006 | 07:41 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
cool, glad to see I could help
Old Apr 24, 2006 | 03:29 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Damn those hood shocks! Every third gen I have ever seen has hood shocks that are/were shot. Oh well.....
Ghettobird52
Jul 5, 2024 11:18 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Bert87
Aug 23, 2015 03:50 PM
Randomtask2
Aug 13, 2015 01:57 AM
