Body Work Help!!!
Old Apr 23, 2006 | 11:56 AM
Brandons'86T/A's Avatar
Car: 86 t/a
Engine: 77 chevy 350
Transmission: stock
Axle/Gears: stock
Body Work Help!!!
Ahhhh... I am getting into the bodywork now...
I am working on sanding down the door... OMG there is sooo much bondo... Its not from rust either... looks like some one got it all dented up really bad and pulled some of em out and then bondo'd over it... Should I sand all of the bondo off???
Or should I leave the bondo on there that is still good...(just sand it all completely down?)
Maybe I should just give it up and buy a new door?
I am really confused and a little angry cuz It looked like there was just a little bondo on the door...(its across alot of door almost)
But I guess more underneath?Some the steel looks clean after bondo was sanded off... no clue why it had bondo? near body line.
I hope some 1 out there has some tips for me(ill try and get some pics some time)
Old Apr 23, 2006 | 03:25 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Hey Brandon,
Where in Michigan are you??...
The size of the area is not an issue here, if it is all good steel underneath. But rather the depth...If it is over and eighth of an inch, I'd consider grinding it all out and re-bumping the panel.
One caveat, look for holes under the bondo, as it is a sign of old school bump work. It compromises the panel and is a poor repair.
Old Apr 23, 2006 | 03:31 PM
91 v6's Avatar
Car: 2002 ranger(showtruck) 90 firebird
Engine: 3.1l
i would take all the bondo off to see exactly what your working with if it is that bad a new door skin isn't too too bad to put on. if the dents are shallow you could go inside the doors and use a flat sheet metal hammer and a dolly that you could find at probally any parts store
Old Apr 24, 2006 | 02:09 PM
Car: 86 t/a
Transmission: stock
Axle/Gears: stock
This is Nathan... Actually the car is mine
Looks like they had some damage on that left side from before... There are some holes where they pulled alot of the dents out... Looks like it must have started craking so the next owner just kept building it up(never did it right first time)
I live in Springport MI(near Jackson) You?
Old Apr 24, 2006 | 06:21 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
Smack dab in the middle of the thumb...(middle of nowhere)
Unless you're into welding and serious repair BEFORE you even start to get the metal straight...You may want to re-think everything and at the least skin the door.
Old Apr 24, 2006 | 07:18 PM
Car: 86 t/a
Transmission: stock
Axle/Gears: stock
How much would a new door skin be?
Just looks like they had to build up alot of bondo to get the door body kit piece on or w/e.
Old Apr 25, 2006 | 07:14 PM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
I haven't found a full door skin, but I think the bottom half is under 35 bucks
Old Apr 25, 2006 | 08:04 PM
Car: 86 t/a
Transmission: stock
Axle/Gears: stock
And you just weld it on? It is all ok... but from the body line down(aprox middle of door down)
How can I get the body kit pieces to fit? since they had to build it up with bondo to work?
Old Apr 25, 2006 | 10:14 PM
alkalore's Avatar
Car: 1992 Camaro RS
Engine: V-8
Transmission: 5-speed
Yeah you'd just weld on the new door skin and then crimp the edges over I'd assume. I'll be trying the same thing in a few months. Before you buy the door skin tho, contact the company, such as The Paddock or Classic Industries, Specialists in GM muscle car restoration and performance parts., and ask them if the lower doorskin will cover what you need to replace. Once you have the new sheetmetal on, you should be able to line up your gfx and drill new holes, it should line up fine assuming that u welded the new part on correctly. Do you have any pictures of what your door looks like?
Old Apr 26, 2006 | 08:05 AM
91 v6's Avatar
Engine: 3.1l
with a skin you remove the old one by grinding off the spot welds on the inside of the door then you put the new one on by folding the edges over and you can spot weld it or use panel bonding adheasive
Old Apr 26, 2006 | 05:53 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
YearOne Online Shopping
Full doorskins available from Year One...No picture, but call them, or email.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
