help removing dash cluster
Old May 4, 2006 | 09:33 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
I have no dash lights for night driving....My shift indicator lights up, the dome light works, the little lights under the vents work, and all of the high beam, turn signal, and error lights work. The fuse is also fine. What i need is a step by step and some advice on removing the dash cluster to replace the lights...
and are there any other problems that could cause this?
the car is a 1991 Camaro RS V6 auto, with the 110mph speedo
thanks!
Old May 4, 2006 | 10:08 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It's your headlight dimmer switch, play with it and it will work. Do a search on how to reppace it if you need to. Mine does the same thing but I live with it.
Old May 4, 2006 | 10:13 PM
draco's Avatar
Engine: 5.0l TBI
thats the **** you pull right? I assume by "play" you mean turn it left and right? or do i need to get in behind it?
Old May 4, 2006 | 10:17 PM
antscrd's Avatar
Car: 91 z28/2014 charger
Engine: 350/ v6
Transmission: 700r4/ auto
you would be assuming correctly. they aren't too difficult to change if you want to, but i helps to have small hands.
Old May 4, 2006 | 10:19 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have to play with mine and it lights up. To replace it you need to remove the dash pad and the speaker and unscrew it from the front behind the pull ****. To remove the pull **** there is a button on the dimmer that you have to press to get the pull **** out, it is on the back of the dimmer or underneath it, a search will help you better.
Old May 4, 2006 | 10:26 PM
draco's Avatar
Engine: 5.0l TBI
I've managed to remove the **** easily, is it necessary to pull the entire dash pad though? =(
Old May 5, 2006 | 06:39 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It is if you want to replace the dimmer.
Old May 5, 2006 | 07:44 PM
jmp91rs's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I had the dash lights to go out in mine a while back and it was due to the bulbs blowing. Not a hard fix either way.
Old May 6, 2006 | 01:23 AM
draco's Avatar
Engine: 5.0l TBI
where do i start to pull the dash pad?
Old May 6, 2006 | 01:35 AM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Underneath the dashpad where it connets to the dash there's an assload of screws and bolts. Undo 'em all.
Near the deforster vent, there's like 3 or 4 screws.
Or atleast on my 84 Firebird it is.
Have at it hon.
Old May 7, 2006 | 01:58 PM
draco's Avatar
Engine: 5.0l TBI
found out its not the dimmer switch, its actually thr bulbs. I have ti go buy 5 of those stupid little twist-in plugs to replace the stock ones as they were discontinued.....
Old May 7, 2006 | 05:37 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
If you can't find them let me know, I have a bunch of plastic housings and bulbs.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
tnrednneck
Aug 13, 2015 08:57 AM
3rdgenparts
Aug 8, 2015 07:09 PM
