tachometer troubles
Old May 9, 2006 | 09:21 PM
bfox88's Avatar
Car: 90 IROC-Z
tachometer troubles
my tach (the RPM gauge) is stuck up high. it doesnt drop down to 0...even when the car is turned off. its stuck way up there too...like around 4500 or so...any idea how to fix this?
Old May 10, 2006 | 09:14 PM
bfox88's Avatar
Car: 90 IROC-Z
i'm sure other people had to have had this problem and fixed it...
Old May 10, 2006 | 11:01 PM
Firebat's Avatar
Replace the tach?
Does it budge or move slightly at all, ever? Could take the tach needle off and set it at 0 RPM and see if it helps.
Old May 11, 2006 | 01:42 PM
bfox88's Avatar
Car: 90 IROC-Z
ya it moves up and down with the RPMs but its starts up at like 4500 or so instead of zero? so you're saying i can take the needle off and just put it back down at zero?
Old May 11, 2006 | 01:45 PM
Firebat's Avatar
wouldn't hurt to try. Just be careful to not break the needle. I think some people use a fork to take it off but i use force because i have spare needles.
Old Jun 22, 2011 | 10:15 PM
oldguy's Avatar
Car: 1991 z28 Coupe
Engine: 305 LB9
Transmission: 5 SPD MAN
Axle/Gears: 3:42 G92
Re: tachometer troubles
My tach is stuck at the high end, when you start the car it goes to zero for a second then goes back to being off the scale at the high end where it sits stuck . Anyone experienced this kind of problem ? Any ideas on repair ? I am starting to restore my 91 1LE and this is one of the repairs on the list
Old Jul 16, 2011 | 07:25 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
all the third gen camaros tachs go bad.there are people on here who have posted how to fix it.use the search.
Old Jul 17, 2011 | 02:13 AM
oldguy's Avatar
Car: 1991 z28 Coupe
Engine: 305 LB9
Thanks for your help
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
