question about formula hood
Old May 30, 2006 | 06:44 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Just inside of the opening, is there supposed to be something to keep water out?
I found one at the junkyard today for $30 (I think it's on an 87-88). It looks straight, and the plastic part and screen are intact. There just isn't anything to keep water out as far as I can tell. It looks like something could be attached to a few vacant screw holes, but there isn't, and I've never really looked at one before to know or not.
It's also been sanded and primered, but the primer has a cracked sorta look to it, plust there's bare metal amlost in a few spots. It was a work in progress apparently. My car will need a new paint job anyway in the next few years, so I'll just sand and primer the crap out of it until then.
I haven't bought it yet though.
Old May 30, 2006 | 07:04 PM
91-TPI-4mula's Avatar
Car: 1991 Formula
Transmission: 5 speed
The '87-'92 domed hoods were sealed from the factory by a removable plate. The '82-'84 domed Trans Am hoods had a honeycomb mesh plate to let air in the air box. There was a plastic trough bolted under the opening that would collect water and direct it toward the drivers side fender ( it was molded with an incline built in to it.) so it would'nt drip on the engine. I found a hood on an '84 T/A that had the complete cold air set-up still on the hood.It had this trough still there, and its now on my '91 Formula. Chris
Old May 30, 2006 | 10:46 PM
Engine: 3.4
Well, this one has the honeycomb mesh opening, so it must be the earlier style.
I forgot that it's on a V6 car, so there's no telling just what year it's from. None of the air stuff is there, but at least it would look cool. I suppose it could make a good exit for the hot engine bay air too.
I'll just have to try to find the water routing stuff, or make something myself.
Old May 31, 2006 | 12:07 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
i drilled a few holes in my hoods buldge for heat venting then siliconed the lip that was sealed off so it wont leak
Old May 31, 2006 | 06:37 AM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I just removed the plastic block-off plate from my Formula hood a while back, with plans to repaint it. Decided to just leave it off...looks cool, and might help a tiny bit with cooling the engine by allowing some fresh air into the bay. If a little bit of water drips on the engine, it isn't going to hurt a thing. Considering removing the hood insulation, though...wouldn't want that collecting water and then holding it against the steel so rust can form!
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
