Problems with changing grill.
Old Jun 9, 2006 | 01:35 AM
Can_of_yum_yum's Avatar
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Axle/Gears: Moser 12 bolt/3.73
k, I just bought a new z28 grill for my rs. I got the kind with the fog light inserts and the red bowtie. Unfortunatly I the holes where the old screws went do not match up for this new grill. How do I mount this, and will I have to drill some holes or somthing in it? I did some searches with no luck. Please help.
Old Jun 9, 2006 | 01:38 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
if ur new bowtie will hide the old hole, then u
can probably just drill a new hole,
and buy a nut and a bolt to just hold them in place.
unless u want to use adhesive or something..
shouldnt be too much of a drilling there,
good luck
Old Jun 9, 2006 | 02:05 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
hmmm
Old Jun 11, 2006 | 10:39 AM
my82roc's Avatar
Car: 89 Iroc Convertible
When I added a camaro fog light grill to my 88 sport coupe I had to drill a couple holes to attach the grill along the edges of the center section as the old louver type grill didnt attach the same way.It was really no big deal at all and it make the car look much better IMO.I used the special torx screws that were used to hold 82-84 camaro grilles on and they work great.
Old Jun 11, 2006 | 01:14 PM
RockerJeff's Avatar
Car: 92 Camaro RS
Engine: 305 5.0L V8 TPI conversion
Transmission: 5 speed
if you use the plastic screws, you can just drill them into the middle section on the inside where the foglights would go without drilling more holes. that's what i did. pretty simple and there aren't a bunch of holes in it.
Old Jun 11, 2006 | 01:36 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
i just did this a couple weeks ago, the top 2 holes on the outer edges line up, so i put those in, then i sucked the grill in as snug as i wanted it, and drilled out the 4 holes in the center section by the bowtie, using the holes already on the grill as a template, then i used some black self tapping screws..6 screws holding it on, ive had the car to 107 and the grills still on so i must have done something right
Old Jun 11, 2006 | 06:24 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I attached mine loosely, by just using the center holes, where the license plate frame mounting was, but yes, everywhere else, you'll need to do some minor drilling. Although you should be able to just hold the screw, tap it with a hammer and then screw it in nicely.
Old Jun 11, 2006 | 10:54 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Only drilling I had to do was the 3 holes in the fron for the license plate bracket (Washington front plate required), all the others lined up pretty good.
Old Jun 12, 2006 | 12:23 AM
camarogirl91's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 5.0 liter(right now!)
Transmission: 700R4/ 4l60E
Axle/Gears: stock
I brought the same grill for my 91 RS and i just drilled two holes on the inside along where the bow tie is instead of where the license plate holes are.That way they are hidden You can't tell at all. Hope this helps some.
Old Jun 12, 2006 | 12:59 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
This reminds me of something. This is why some people, believe it or not, think they have a Z28 when they have a RS, simply because the license plate mounting assembly, says Z28 on it *LOL*
Old Jun 12, 2006 | 01:20 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
well I bought a 'bowtie' grill to replace my 'camaro' grill, I'm hoping it is a direct 100% bolt-in... ?
Old Jun 13, 2006 | 12:31 AM
Car: 1991 Camaro RS
Axle/Gears: stock
That is funny people believe that! but least we know what to look for!
Old Jun 15, 2006 | 12:17 AM
Car: 1989 Camaro RS
Engine: 355
Transmission: T-10
Well, I talked to a guy in my area today (Checker auto store), and he told me that the RS and Z28 were different bumpers all together. He said there is no way it will really line up with out drilling or making some brackets because the whole bumper is different on the iroc. So I guess I'm going to just build a simple little bracket and let you know how it goes.
Old Jun 15, 2006 | 01:55 AM
Kyuusei's Avatar
Car: 1985 Camaro
Engine: 2.8L V6
It depended on the years of the RS and the Z28. They had the same bumper cover in the later years, and different ones earlier on.
Old Jun 15, 2006 | 10:56 AM
89_IROC_98U's Avatar
with the above poster.
IIRC, the only difference is the grille itself from '85-'92 (and, of course, the ground effects for '91 and '92). The RS had a different lower valance - "chin" spoiler - than Z28 and IROC-Z (again, IIRC)
You will likely have to drill if the holes don't line up; I recall having done this with my '92 RS when I installed a Z28 grille. Drilling new holes won't hurt anything. They won't even be noticed if done properly.
Alternatively, you could pickup some "Hi-Temp/Hi-Strength Superlock Fasteners" from RadioShack - this is an exceptionally strong fastener that's similar in design to velcro. I've used it to attach rear blackouts, and it's held nicely even during prolonged speeds exceeding 100mph. The part number is '64-2360'.
- 89_IROC
Old Jun 15, 2006 | 10:17 PM
fbodyguy86's Avatar
Car: 92 camaro rs
i swapped out the old louver style grille to the "camaro" grill with fog light openings just unscrewed the old one and screwed on the new one no drilling or fabricating required
Old Jun 16, 2006 | 01:16 AM
Car: 1991 Camaro RS
Axle/Gears: stock
good luck on your project, if I can be any hlp let me know!
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 12, 2015 06:39 AM
