Will Camaro doors fit?
Old Jun 10, 2006 | 07:08 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
Hey. I have an '86 Firebird that I'm currently working on. I live in Canada so the doors are pretty rusted (too rusted to repair). I was wondering if Camaro doors could possibly fit on my car, seeing as how I'm having a hard time finding Firebird doors around here that are worth buying. I heard that Camaro doors are a little bit smaller than Firebird doors.
If anyone could clear this up for me, it would be greatly appreciated.
Thanks in advance.
Old Jun 10, 2006 | 07:27 PM
slim64's Avatar
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
Doors
I have been told that all third gen doors will fit all third gen cars, camaro or firebird.
In terms of gfx mounting holes, they might be different, but the doors themselves are the same
Old Jun 10, 2006 | 07:35 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Thanks slim. I was thinkin it should work out, but I didn't want to go out and buy doors that wouldn't fit. Also, my car doesn't have and gfx, it's just plain-jane.
I'm slowly but surely restoring it. I'll post pics of how it's comin along pretty soon.
Old Jun 10, 2006 | 07:47 PM
slim64's Avatar
Not a problem.
Wish i could remember where i read that they were the same... if i find it, ill link to it for you.
Old Jun 10, 2006 | 08:06 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Thanks, that link would be great.
Old Jun 10, 2006 | 08:09 PM
slim64's Avatar
https://www.thirdgen.org/forums/body...firebird+doors
That should provide you with the info you need to see what is the same and not.
Old Jun 10, 2006 | 08:18 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Thanks for the help. That info broadened my search.
eddie jr's Avatar
Poject 86,
Just wondering, are the doors all rusted in the typical area....along the bottom of the door? If so you can save a bundle by getting the outer lower skin (8in) and the actual door bottom (which re-creates the flange that the skin wraps around). Then you will have a 100% rust free door. That is what I did when I restored mine. I got them from "Cross Canada". I can't remember the exact price but they are very cheap......I think they even mad a mistake and gave me the jobber rate or something as I recall it only being about 15$ or so per door.
Just a thought anyway.
Oh and I see you are from Ontario....where abouts??
Old Jun 10, 2006 | 08:30 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Both my doors are rusted right-thru in the bottom corners. I figured it would be less of a hassle just to buy doors that are in pretty good shape. You being a canadian know how hard it is to find nice used doors
I'm in Windsor. Where-abouts are you?
Old Jun 10, 2006 | 09:09 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
i cant remember what i saw it on but i saw a third gen with ground effects that had the bottom of the outer door skin indented under the ground effects...make sure you look for this...otherwise they are the same
Old Jun 10, 2006 | 09:16 PM
eddie jr's Avatar
Yeah, I hear ya. I couldn't find decent ones either. The ones you do find still have some rust on them so why bother is what I figured....more money and a rust problem in the future. The big problem is ideally (unless you get lucky) you have to generally get southern doors, but by the time ship them here your in to many hundreds $$
I guess it depends on exactly how bad they are. One of mine was worse than the other (holes in the inside bottom corners) whereas the other just needed the lower skin and bottom piece. There is no question it is more work though, you are right there. I was on a tight budget though at the time. I will try to post some pics for ya.
By the way I am in KW.
Old Jun 10, 2006 | 09:38 PM
eddie jr's Avatar
Here are before some pics:
Attached Thumbnails Will Camaro doors fit?-car-004.jpg   Will Camaro doors fit?-door1.jpg   Will Camaro doors fit?-door2.jpg
Old Jun 10, 2006 | 09:40 PM
eddie jr's Avatar
New patches and bad stuff cut out:
Attached Thumbnails Will Camaro doors fit?-car-006.jpg   Will Camaro doors fit?-door4.jpg   Will Camaro doors fit?-door3.jpg
Old Jun 10, 2006 | 09:41 PM
eddie jr's Avatar
New flange and final product:
Attached Thumbnails Will Camaro doors fit?-car-005.jpg   Will Camaro doors fit?-car-013.jpg
Old Jun 11, 2006 | 12:15 AM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Your doors turned out lookin damn good man. My doors are worse. I found a place in London that has local doors for $100 each, and southern doors for $150. The guy said he had loads of doors. I might go out there to check them out.
Also, do you know anyplace I could find 91-92 bumpers like these http://www.fbodymotorsports.com/inc/sdetail/16391 that dont cost a fortune?
I wanna throw the fron and rear 91-92 bumpers on my car.
I just realised I spelled Project wrong heh.
Old Jun 12, 2006 | 09:46 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Here's a few pics of my doors. Not worth repairing if you ask me. The passenger side is also really wavy. The door was hit underneath the mirror, and the previous owner pulled the mirror up to pop the dent out. Bogus!
Attached Thumbnails Will Camaro doors fit?-picture-099.jpg   Will Camaro doors fit?-picture-100.jpg   Will Camaro doors fit?-picture-101.jpg
Old Jun 12, 2006 | 11:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
bondo time!!!!
Fiberglass bondo that is, do it right don't 'cha know!
Old Jun 12, 2006 | 11:37 PM
eddie jr's Avatar
Yeah those are definitely weathered, that's for sure. THat price in london doesn't sound that bad though. Check that out for sure. I know a guy who did up a cavalier and put far more than that into just the doors. Just look them over good on the inside to make sure there is not a lot of rust starting in the seam. Is that Shaw's or Corey's? Those are two really good wreckers in the london area. I may be going to the wreckers on the weekend and can have a look for ya if you don't have them yet. I will take note if I see any newer style bumpers too.
Check out the local board I PM'd you too as I remember a couple cars being parted out recently. Might be worth a shot.
Old Jun 13, 2006 | 09:06 AM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
I'm really not sure where they are at. I found the number in the Shoreline, and put the number somewhere around here. If you happen to go, and see any worthy doors around, I'd really appreciate it. When I went to the wreckers in london (I believe it was Coery's), there was a whole firebird there, same colour as mine right down to the red interior. Only thing wrong wtih that car was a little rust on the quarter panels, and I think the engine seized. I went with two of my friends in a pickup, and the bed was filled with Bonneville parts, so I couldn't pick up the doors
I gotta get back down to London to find doors, but it's a long drive from Windsor, and I'd be goin with my friend in his truck, which is a pig on gas. So we can't just go down there to look. I have to know that there are decent doors somewhere there first. No need to look for those newer bumpers though, I want to do this to the lights.
Thanks a lot for the feedback guys. And I'm still waitin to see other pics of how your doors came out eddie
Old Jun 13, 2006 | 10:36 AM
eddie jr's Avatar
Here are a couple more, including when it came out of the paint shop.
Attached Thumbnails Will Camaro doors fit?-door6.jpg   Will Camaro doors fit?-door7.jpg   Will Camaro doors fit?-door8.jpg
Old Jun 13, 2006 | 11:00 AM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
That looks great man! My bird is exactly like yours, except for the spoiler. It even has the body mouldings taken off and its red. I hope mine turns out lookin that good.
Old Jun 13, 2006 | 11:38 AM
eddie jr's Avatar
Actually I too the body mouldings from a later 80's model (87-up I think) that are wider and body colour to replace the cheesy black ones I had. Here is a pic with everything back together as well as a before pic to show the difference:
Attached Thumbnails Will Camaro doors fit?-car.jpg   Will Camaro doors fit?-car1a.jpg   Will Camaro doors fit?-car-019.jpg
Old Jun 13, 2006 | 12:56 PM
dwilliamsfaq's Avatar
Car: Modified 91 RS Camaro
Engine: TBI 350 +.060 w/ vortech heads
Transmission: T-5 swap
Axle/Gears: 2.73 posi - daily
doors
The doors are the same up to 89 I believe the major problem is going to be the holes for the ground effects, they are not drilled in the same place. (Firebird doors are drilled above the body line and Camaros are below) I just put Firebird doors on my Camaro and they fit like a glove (91 RS). I do not know what the difference is between the years, but it always comes up 82-89 and 90-92.peace
sorry, for some reason it did not show the replys when I first looked at this
Old Jun 13, 2006 | 01:05 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Thanks dwilliams. A friend of mine had an '89 firebird if I'm not mistaken, with '86 camaro doors on it. They didn't seem to fit right. When the doors were closed, the gaps around the doors seemed a little big. That's why I wasn't sure if camaro doors would work on a 'bird. Your car looks great eddie. Did you paint it yourself? Or did you take it somewhere?
Old Jun 13, 2006 | 05:41 PM
eddie jr's Avatar
Thanks, I did all the restoration work myself (a lot more was needed than just the doors!), all the body work, taped it up, primed it myself in the booth (at a rent-a-bay), did all the final sanding and then had a professional put the final paint on.
Old Jun 13, 2006 | 05:49 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Awesome. Did you send it to Maco or a local shop? I don't mean to be a pest. I'd just like to hear how people are getting their cars finished, seeing as how mine needs to be painted when I'm done the bodywork. My friend that's helping me with the car has an uncle that does AMAZING work on cars, paint AND bodywork. So my friend was thinkin about painting it. I'm tryin not to dump too much money into the car all at once, since it's my first, and I'm only 22, not makin a lot of money.
Old Jun 13, 2006 | 06:37 PM
eddie jr's Avatar
Oh no, not Maaco Avoid them like the plague if you want anything lasting and really professional (fine for the winter beaters)......i have seen a lot of work from them and you get what you pay for....cars rusting again in under 6 months etc. I wanted to keep the cost way down too and that is why I did the work myself, but for paint I took it to a Rent-A-Bay (you rent the paint booth). At this one you can either do it yourself or have the professional do it for you for a labour fee. By going here though all you pay for is the paint and the labour to paint it (if you choose that route) is only 85.00 for acrylic enamel and 115 for base/clear....dirt cheap. The guy that works at this particular rent-a-bay is rumoured to be the best in the Niagara Region (they do a lot of work for dealers as well) and ended up doing an awesome job. There is less orange peel (hardly evident) than in a factory paint job on newer cars without any wet sanding at all. I sprayed the primer on myself, again to save cost, and since it is not crucial if you get drips etc since the whole thing has to be sanded again anyway. They use top notch paint too (Dupont) so you are getting quality paint and not that cheap synthetic enamel or whatever it is that is used at economy places.
If there are any rent-a-bay's in your area, definitely something to look into. Definitley worth it.
Old Jun 14, 2006 | 05:45 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Haha, I heard that maco was crap from others too. There's a rent-a-bay here. I'm gonna call them up and ask them how much it would cost for a pro to do it, just to be safe.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BlackTopKing
Aug 19, 2015 12:13 PM
89lsc
Aug 14, 2015 04:58 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
