removing front seatbelt
Old Jun 23, 2006 | 01:45 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
when I bought my 4th gen seats(used but mint)
it didnt come with the seatbelt guide.
so I bought the seatbelt guide off hawk3rdgen
Hawks Third Gen Parts-82-02 Camaro and Firebird Parts - Camaro or Firebird 93-2002 Seatbelt Shoulder Guide, Coupe or T-Top
I thought it would be a snap to take the seatbelt off just like the
rear one.. but front one seems impossible to take off
there's a bolt retaining the buttom part,
and I used a starwrench and it keeps slipping.. almost looks like its welded in
to the car or something?
any1 know a good way to remove the seatbelt temporary?
just the front ones... my car is a 91 RS,
if that matters.
thanks in advance and yes I did search "seatbelt" "seatbelt remove"
etc..
Old Jun 23, 2006 | 01:57 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
did you use the right torx bit? i believe it's a t-55 or t-57 i cant remember it's been awhile. they're in there really good i broke a 5 bits taking out those four. (front and back) I replaced them with a hex head for easier removal should i decide to remove them for some reason in the future.
Old Jun 23, 2006 | 02:00 AM
MavViper's Avatar
They are on there very tight, and that's for a good reason. 87CIZ is right, it's either a T-55 or T-57. You need to get the right size otherwise you will either break the bit or strip the bolt, both of which you don't want to do.
I recommend going out and getting a decent torx bit set, as that will save you time and effort. As far as getting that bolt out, get the proper size bit and a little elbow grease, and it should loosen up.
Old Jun 23, 2006 | 02:20 AM
sogabe's Avatar
Engine: 3.1L
yeah, I do have a brand new set of torx bit..it wasnt star wrench, my bad.
i used a 47 t50 was a bit too big.
with an extension since the cover's on the way, I jsut keep slipping,
and my wrench tip kinda stripped a little bti, so I didnt wanna keep trying..
if I remove the buttom assembly though,
after that can I get just the belt out easily so I can put the guide in?
Old Jun 23, 2006 | 04:03 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
even iff you got the reciever off the bottom, there is no way to get the guide on around it. you only have one option here. you see how there are two holes on the guide for screws. ? cut the guide right between them, slide it on around the seat belt and screw it into the seat. problem solved.
Old Jun 23, 2006 | 08:56 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Just a heads-up. Those bolts are loctited (blue) in. Atleast mine were, I just removed the interior of my car a couple of days ago. They were a little stiff, and the driver's side bolt head showed some stripping after some torqueing, but they will come out.
Old Jun 23, 2006 | 01:57 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
on my 4th gen camaro seats i just reused the stock thirdgen guide. it screwed into place no problem. come to think of it it may have been a t-47 i thought it was an odd size. anyway give your thirdgen guides a go and see what you think.
Old Jun 23, 2006 | 03:17 PM
sogabe's Avatar
Engine: 3.1L
Xeno ur right.. I guess there's no way unless I take the stiches off,
which I don erally wanna do..
I guess ill grind the guide off in the middle like u said,
thanks!
Old Jun 24, 2006 | 12:06 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
torx size for seat belts 82-02 is a t-50
Old Jun 24, 2006 | 06:13 PM
MNformula350's Avatar
The CORRECT torx bit for GM seatbelts (including 3rdgens) is a T-47
Old Jun 24, 2006 | 08:29 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I learned at work that a handy dandy impact wrench can loosen just about anything.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Mar 10, 2016 10:35 PM
3rdgenparts
Aug 8, 2015 07:09 PM
