por-15
Old Jul 11, 2006 | 12:50 AM
dustpusher's Avatar
Car: 88 IROC-Z
por-15
Has anybody ever sprayed it?Can it be sprayed without thinning?I plan on using it on the floorboards and underneath.
Old Jul 11, 2006 | 01:50 AM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
Old Jul 11, 2006 | 01:57 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by CarterCarbureto
you beat me to the punch Yes dude or dudet, welcome to the forums but before you ask, search, it has been covered too many times to count and it has all been archived. Let your fingers do the walking and you will find a wealth on info.
Old Jul 11, 2006 | 12:57 PM
dustpusher's Avatar
Car: 88 IROC-Z
I tried a search didnt get the info i wanted.Thanks for your responses.I will try searching again when i have another hour or two to kill. Thanks Dave
Old Jul 20, 2006 | 12:19 AM
Belker's Avatar
Look at some internet sites that sell POR-15. They have FAQs and info on the products they sell. You should read their directions.
Old Jul 20, 2006 | 06:29 AM
just2quickz28's Avatar
Car: 86 IROC
This is directly from the Por15 website
SPRAY APPLICATION:
Use 30-35 lbs pressure for normal gloss. Reduce pressure for lower gloss (20-25 lbs). Thin only with POR-15 Solvent, if necessary, but do not thin more than 5%.
TO TOPCOAT A FULLY CURED POR-15 SURFACE:
Wet sand with 600 grit until gloss is dull, then paint, or use POR-15 Tie-Coat Primer directly on the cured POR-15 surface, then topcoat as desired. NOTE: Never topcoat a POR-15 surface that hasn't dried, as this will ruin the coat already down.
Use POR-15 Solvent or lacquer thinner for cleanup, which must be done before POR-15 dries. NOTE: Organic vapor particulate respirators, NIOSH/MSHA approved, must be used when spraying POR-15.
Moisture will shorten the life of unused POR-15. See our 'Residual Moisture - Little known Facts' page to learn some little-known facts about residual moisture.
Seal can or jar immediately after using. We recommend placing plastic wrap between lid can and storing in a cool dark place.
Old Jul 20, 2006 | 07:40 AM
vindoo's Avatar
Car: 89 Formula 350
I've got to get some of that stuff and give it a try...Havent attempted anything with it yet, but it looks like you get great results when used properly.
Old Jul 20, 2006 | 08:46 AM
eddie jr's Avatar
Unless it is i a high show area, I wouldn't bother because it has pretty amazing "self leveling" abilities and comes out flat after brushing (the gloss does anyway, that's all I use). You basically can't tell it has been brushed. The other thing though is that if it is a show area or any area for that matter that sees sunlight or reflected sunlight and you want it to look good, forget POR15, UV fades it to a milky colour. It will still give protection but look ****ty. You have to use their chasis coat black or other topcoat if you want it to look good, and those don't have the same self leveling abilities (still not bad though).
Old Jul 22, 2006 | 08:29 PM
dustpusher's Avatar
Car: 88 IROC-Z
Thanks guys i brushed and sprayed it worked great.Stuff is a real pain in the rear to get off of you.Seems to be alot better than undercoating. Thanks again for all of your replies.
DuronClocker
Nov 17, 2004 12:54 PM
Belker
Apr 22, 2002 09:07 AM
Buck268
Aftermarket Product Review
Feb 13, 2002 05:09 PM
red
Oct 15, 2001 02:57 PM
TomP
Aug 1, 2000 10:27 AM
