POR-15 or Zero-RUST ?
Old Oct 8, 2001 | 09:04 PM
red's Avatar
red
Car: 91 Camaro vert & 69 Camaro
I am repainting the interior of my 69 Camaro while the seats, dash, and wires are out. There is some rust.
I have read lots of things about POR-15 but Zero-RUST has been recommended as just as good and cheaper.
Does anyone have any experience with Zero-Rust or comparision to POR-15?
ZeroRust site: http://www.zerorust.com/index.htm
POR-15 site: http: //www.por15.com/
Old Oct 8, 2001 | 09:06 PM
FiReBReTHa's Avatar
im intrested in this too...
and how do you get the old stuff off the bottom, i have a 91 n pretty good condition
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 9, 2001 | 08:52 AM
WK Irish's Avatar
Red:
If you don't receive any responses to your question, go to www.autobodystore.com and check both the forum archives and current postings for several discussions on this very subject.
Len Stuart's site (also in NJ) is an excellent info source on body & paint topics.
Be certain to check up on Isocyanates when deciding, as many DIYer's are unaware of their dangers.
HTH
WK Irish
See ya' on the net at www.zerorust.com
Old Oct 9, 2001 | 01:50 PM
MichaelRBrumm's Avatar
Thanks for the warnings about isocyanates! I guess I'll be using POR-15 only where I can apply it with a brush and where I won't sand. I'll use ZeroRust on everything else.
Of course, none of the protective stuff we put on our cars is good for us. Kinda makes me wonder about applying ANYTHING, including ZeroRust. Maybe I should just get one of those supplied air breathers, etc...
Also, I've read that POR-15 is stronger than ZeroRust in a few message boards, but I haven't seen any definative face-off of the two products.
Old Oct 10, 2001 | 02:13 PM
WK Irish's Avatar
Michael:
There has been some discussion about the safety of even brushing moisture cured urethanes like POR 15, so do your due diligence before proceeding.
As to strengths/weaknesses:
ZR, at 3 mils (3 one thousands) dft (dry film thickness) produced 2000+ hours in a commonly used test by paint producers (salt spray cabinet test) and competing products fell way short of that.
For ease of use, safety, unlimited shelf life, repairability (if necessary on down the road) AND cost, ZR is a very viable alternative for controlling rust and corrosion.
ZR's major advantage for DIYer's, is that a media blast (whether sand or otherwise) is NOT a requirement, making a less than white metal restoration job realistic and attainable.
Check us out.
WK Irish
Old Oct 13, 2001 | 04:01 AM
Well, time under salt spray is good and all, but I'm more concerned about strength and resistance to hard wear. I'd like to see a hammer test (POR-15 vs Zero-Rust).
Most of the stuff I planned to paint with POR-15 is on the underside of the car, where rocks chip away at it.
Old Oct 13, 2001 | 10:24 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Well, you could always give it a coat of Zero-Rust, then cover that in Por-15 to keep rock chips away.
Old Oct 15, 2001 | 05:34 AM
Yeah, except you pretty much need to apply the POR-15 directly to bare metal. The Zero-Rust can be applied over POR-15, though...
But, the whole thing is I'd like to just buy one product that isn't a biohazard, sprays on, prevents rust, and resists chipping.
Old Oct 15, 2001 | 02:57 PM
WK Irish's Avatar
Michael:
We're aware of several guys who have done/are doing side-by-side tests of various rust control products and the former have consistently reported ZR is tough and does in fact resist chipping.
I can harp all day long on its merits, but there's only one way to prove/disprove what we know about ZR. Perhaps some of this forums ZR users will chime in re: their experience so you don't have to take just my word.
WK Irish
benoit454
Mar 18, 2005 08:57 PM
DuronClocker
Nov 17, 2004 12:54 PM
Belker
Apr 22, 2002 09:07 AM
Buck268
Aftermarket Product Review
Feb 13, 2002 05:09 PM
TomP
Aug 1, 2000 10:27 AM
