paint question
Old Aug 18, 2006 | 10:43 PM
bbatton's Avatar
Car: 86 Camaro
Transmission: 5 speed
paint question
Ok I sprayed my color on It is a 1 step acrylic paint, It came out with a lot of orange peel, My question. Do I color sand it or could I just spray a Clear coat and color sand the clear? Would that get rid of the orange peel, even though the 1st coat of paint also has orange peel? Would the 1st coat with orange peel show thru the clear? Or should I just resand and put another coat of paint on.
Old Aug 19, 2006 | 02:09 PM
bbatton's Avatar
Car: 86 Camaro
anyone got any tips of what I could do?
Thx
Old Aug 22, 2006 | 05:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ORANGE YOU GLAD
If you clear coat over orange peel your clear
coat will follow all the orange peel you left in.
Therefore:
1. Make sure you painted it thick enuff before hand.
2. Sand the orange peel off.
3. Now, after sanding your paint will be smooth but dull.
4. Now you’re ready for clear coat.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Old Aug 22, 2006 | 06:08 PM
bbatton's Avatar
Car: 86 Camaro
Therefore:
Happy Racing !
Thank You I was afraid That's what I might have to do .
Old Aug 27, 2006 | 04:38 PM
bbatton's Avatar
Car: 86 Camaro
Therefore:
Happy Racing !
Now Should I wet Sand or Dry sand with 1500-2000 ?
Old Aug 27, 2006 | 05:04 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Axle/Gears: Auburn Limited-slip w/3:73 gears
How long has it been since you painted the car?
Is it a metallic color?
Did you use any hardener in the paint, when sprayed?
How many coats did you put on?
Help me with these questions, and I can better give you the answers.
Leon.
Old Aug 27, 2006 | 05:35 PM
bbatton's Avatar
Car: 86 Camaro
Leon.
Yes it is metallic and I did use Hardener and it's been about 2 weeks since I painted it.
I have 3 coats of paint on it.
Old Aug 27, 2006 | 05:42 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Orange Peel
go to Welcome to Autobodystore.com where the forums will have all you need to know and read, and you will be fine...
http://www.autobodystore.com/
Old Aug 27, 2006 | 06:24 PM
1tinindian's Avatar
Well then, I'm afraid you CAN NOT wet sand and JUST spray clear on it.
You can't wet sand a metallic single stage paint, either to spray clear on it, OR buff it out, as you will streak the metaliic particles in the paint, and will look terrible.
I'm going to have to say, if it's that bad too where you have to sand orange peel down, just to get the paint flat and smooth, you're going to have to repaint the car.
No way around it, with the single stage metallic.
You could have gotten away with it, if it were a solid (non-metallic) color, or if it was clear coated in the first place.
Better luck next time, bud.
I wish I had better news for you.
Leon.
Old Aug 27, 2006 | 10:07 PM
jay92,85,79's Avatar
Car: 85z28,
been there done that.. Looks like crap if u wet sand SS metallic .
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
