Is acetone good for removing wax and grease from paint?
Old Sep 3, 2006 | 10:01 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Just what the title says I am painting few areas on my car with some duplicolor because the paint is peeling so bad, I am worried bout it starting to rust. I will be sanding with 800/1000 grit to clean it up and painting the spots, is acetone a of for cleaning before painting?
Old Sep 3, 2006 | 10:13 PM
j dezzy's Avatar
Car: 87 TA
...not sure if it is a good way...I use acetone to remove paint from cement....
Old Sep 3, 2006 | 10:16 PM
firstfirebird's Avatar
Denatured alcohol would be good if your going to use a chemical, how about a tack cloth?
Old Sep 3, 2006 | 10:43 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
a tack cloth would only remove dust, i do that to, i want to make sure that any oil from my hands, or left over wax is gone. i cant find true wax and grease romover. i can get denatured alchol though.
Old Sep 4, 2006 | 06:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dish washing soap?
JamesC
Old Sep 4, 2006 | 11:36 AM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
they sell some grease and wax remover at most parts stores, not sure about if its gunna do any damgage to finished paint though.
Old Sep 4, 2006 | 12:05 PM
the problem with them is you still need to use something to remove the residue left behind
Old Sep 6, 2006 | 02:44 PM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
I Use westleys bleech white,then dish soap,Then amonia free glass cleaner,
then sand,then glass cleaner again,tack cloth, then paint.
thats on a complete paint job.
The glass cleaner will remove any residue,and dirt.and the tack cloth will remove anything left behind from wiping off the glass cleaner.
If your just doing a few body panels,try not to hit the good panels with the westleys,
Westleys is a spray on solution that you can buy anywere,that is tipically used for under hood cleaning,and is great for wax/grease removal.
Spray in on,let sit a few minutes,then hose it off.pretty simple.
Hope it helps ya
Old Sep 8, 2006 | 10:16 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Most parts stores, I think AutoZone too, has a cleaner called PrepSol that is designed for this. Sometimes it's really hard to get a good paint finish without fisheyes and craters. Sure gets aggravating when this happens.
Old Sep 8, 2006 | 11:00 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
yes, i use asitone alot for paint prep... it works great
Old Sep 16, 2006 | 10:38 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
thanks for all the replys, used dish soap, glass cleaner, and tack cloth. looks like it worked well ... thanks agian.
Old Sep 17, 2006 | 04:27 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Acetone
You first need to wash with water and soap to remove water soluable chemicals. Then use acetone which is a great solvent to remove wax, grease, oil. I work in a lab and we use acetone for all analytical testing because is does not leave behind any residue and evaporates very quickly.
Old Sep 17, 2006 | 07:22 PM
Does denatured alcohol leave any residue?
Old Sep 17, 2006 | 09:05 PM
wildjyoung's Avatar
Acetone
Denatured alcohol can leave some residue. They denature the alcohol using chemicals (i.e. triethyl citrate) which does not evaporate. This would be left behind; however usually the denaturing chemical is in the alcohol at a very low percentage (2%). I do not know what effect, if any, this would have on paint.
LilHot
South Central
Apr 13, 2026 11:46 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
