Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)
Old Dec 3, 2008 | 09:11 PM
  #1501
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Re: Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LS
More pics.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3071821879_4e2dfefc78_o.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3071822513_d9e8c6811f_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3071823637_f0514b3fdb_b.jpg
Old Dec 3, 2008 | 09:17 PM
  #1502
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Also posted new exhaust pics at the end of the previous page.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3071826625_76ce3fa883_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3071825315_9bec33a57b_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3071824837_976f3c2da8_b.jpg
Old Dec 3, 2008 | 10:02 PM
  #1503
anthony714's Avatar
freaking a neil...i want to pay you to go for a ride one day.this is the ultimate 3rd gen and a bad *** car period. we need to contact a national magazine,get this sucker exposed and into the public light.the world must know about this car.its far and above unique and in a world of its own.
Old Dec 3, 2008 | 10:17 PM
  #1504
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
exhaust is looking wild!
dual 3"?
Old Dec 3, 2008 | 10:34 PM
  #1505
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Thanks man! That was one hell of a compliment and yes getting this car in a magazine would be cool! I also would like to get it into SEMA next year, we'll see???
dual 3"?
Thanks and yes, it is a dual 3" system.
Old Dec 3, 2008 | 10:56 PM
  #1506
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
So the guy doing the exhaust is in Dallas?
Old Dec 3, 2008 | 11:13 PM
  #1507
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Yes, he is in Dallas.
Old Dec 4, 2008 | 12:30 AM
  #1508
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Well, you know Jim would say the same thing I'm gonna...... We need to tweak it a bit before sema....
ie.. media blast / paint / or powder coat: rear end, sway bars, brackets, panhard bar, tranny x-member, and any rusty screws/bolts/plugs, polish diff cover, fix or replace the screw holding on the center ground effect in rear area or find better way of attaching, send car back to paint shop for touch-ups and detailing, have entire exhaust jet-hot coated, install tru-trac and intake, interior upholstery, new shocks and or struts and or air-ride, tune DFI (my friend with the turbo stang is a wiz at FAST XFI, we need to build a custom cold air intake once manifold is in place, might have to make the A/C lines, etc.. etc..
I'm sure there are some things that I missed, but that's all I can think of at the moment.
I also think the GMMG setup in the rear would look and sound killer. Fatal88 has it on his LS-1 vert, sounds awesome!
Anywho, it's looking pretty damn good!
I'll call you after work tomorrow
Old Dec 4, 2008 | 08:28 AM
  #1509
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Neil looks great so far BUT and I really hate to say this but that cross member is going to flex ALOT. Ive built a couple and you really need to have better vertical support. yours is like a cantilever and its going to put ALOT of stress on the forward mounting holes, they aren’t meant to take torsional stress like that and will fatigue the metal around the bolt. Also the flat piece that mounts to the tranny will need to be reinforced that will flex and deform… The idea looks good you just need to reinforce the area perpendicular to where the tranny mounts, just reinforce it in the vertical direction and any and all flex should be taken care of.
Also on the wiring location, your going to hate life if you leave it like that and drive in the rain. While the fender liners do a good job they don’t completely seal that front area and you will get splashing up there. If you keep it in that area you need to put the connectors in a sealed and vented box. I would recommend looking at another option.
If you could find a way to put the large connectors inside the passenger compartment and then inside the car drill through the floor into the frame rail and then run the wires for the fans and lights up through the frame rail to the front bumper you would completely get rid of ALL the wiring in the engine bay/wheel well. This might require you to get creative and may need to lengthen some of the wires but itll be a MUCH cleaner look and itll put the connector block in the passenger compartment which is much better since im pretty sure it isn’t a weather proof setup.
other than that constructive critisism your **** is kicking *** and taking names! keep it up!
EDIT: and dude get these up on a picture hosting site so I can scroll through them without having to weed through all the posts!! PLEASE!!
Old Dec 4, 2008 | 02:16 PM
  #1510
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Thanks dude and yes, all the items you have list are in progress or will be done, well most...not all of the things you mentioned...NO AIR RIDE. Coil overs are going over in the rear. For now, I won't jet hot the exhaust, maybe later after I drive it for a while. Oh and I already have MagnaFlo Mufflers which will I will be running!
Old Dec 4, 2008 | 02:22 PM
  #1511
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Thanks very much for the input! Constructive criticism is very good and can be very helpful. I will talk to the fabricator about strengthening the transmission crossmember before I have it powder coated.
As for the fuse boxes, yeah, I will definitely cover them up and shield them as best I can against water. I was thinking of making an aluminum cover which would completely seal in the fuse boxes from underspray and then add the plastic inner fender liner. Once I get the car back i'll spend some time with that and try and figure something out.
But hey, I am open to ideas!!!
Old Dec 4, 2008 | 05:10 PM
  #1512
RoadTech Online's Avatar
Car: Jeep
Engine: small
Transmission: automatic
Axle/Gears: rear
The pictures you guys have been seeing are only progress pictures ! So Yes the trans mount looks weak, because it is weak...but is isnt finished. If you notice the mandrel bends arent welded up either, but no one mentioned that
Old Dec 6, 2008 | 04:34 PM
  #1513
BigDRay's Avatar
Car: 88 Iroc-Z
Engine: 350 5.7 TPI
Duuuuude...this is unreal. It saddens me that my car will never be 1/4th as good as this.
Old Dec 27, 2008 | 11:08 AM
  #1514
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Thanks man! I just can't wait until the engine fires up for the first time!!!
Old Dec 27, 2008 | 11:23 AM
  #1515
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
I hope everyone had a Merry Christmas! I have updates for you on the exhaust system and modification to the k-member which was needed in order to drop the oil pan. I have to remove the oil pan because the bell housing plate was preventing the oil pan from sealing properly...the rear oil pan rail was pressed too tightly up against the bellhousing plate and residual oil in the engine (from assembly) was leaking from that location. Sucks this happened, but at least I found out now rather than later. John did an excellent job in modifying the k-member to allow removal of the oil pan wiht the engine in the car, cause I did not want to have to remove the engine this soon!
Here are pics of the powder coated upper/lower PH bars. John fabricated the upper bar to provide good clearance for the exhaust. The powder coat appears washout from the flash, but it is a nice silver. I will have the sway bar and lower control arms powder coated in silver as well.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3113986663_9db3c2361b_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3113987953_558f7ea4a4_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3114818304_c0e0b016a4_b.jpg
Old Dec 27, 2008 | 11:27 AM
  #1516
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
The trans crossmember powder coated in gloss black. Note, additional gussets were added to strengthen the brace even more. It looks very solid!
Also, a pic of the header tube with the welds smoothed.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3114818760_18acc99874_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3114818974_afa0b2d099_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3121220358_8690451212_b.jpg
Old Dec 27, 2008 | 11:30 AM
  #1517
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Both Magnaflows installed.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3125691911_53025c61eb_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3125694497_d89301babe_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3125698277_f50f54e87d_b.jpg
Old Dec 27, 2008 | 11:32 AM
  #1518
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
More muffler pics....
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3126520456_b4b21cd28f_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3126525696_175874661a_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3125695333_28d6ed06aa_b.jpg
Old Dec 27, 2008 | 11:39 AM
  #1519
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Modified K-member pics. The first pic shows the center section removed (cut out) and then John's fabricated, much stronger piece installed. It is a bolt in section which will allow oil pan removal . Note, the oil pan is not flush with the block, only a few bolts are holding it in, so it appears as if the center section is not straight or parallel, but it is.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3129710988_2e25672e98_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3139737518_573b9498e9_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3139738422_d6649e55da_b.jpg
Old Dec 27, 2008 | 05:00 PM
  #1520
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
lookin mighty fine Neil!!
I bet your going to have permagrin when this car is finally up and running!
Old Dec 28, 2008 | 01:31 AM
  #1521
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It's looking pretty bada$$ !!
But, just noticed....
Post #1518 , 1st pic, it's looks like the passenger side muffler needs to be moved a couple of inches towards the outside (driver tip is directly under the amber turn signal, passenger tip is directly under the reverse light).....
I'll call ya in the morning.
Old Dec 28, 2008 | 09:49 AM
  #1522
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Do have any magazine ties yet? I'll see if I can't get someone to check this thread out and maybe get a hold of you.
Old Dec 28, 2008 | 12:48 PM
  #1523
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I wouldn't put the tips on until the spare-tire well can be scalloped out in order to make room to move the passenger side muffler. When that's done, I would use Corsa double walled stainless dual tips on each side. Corsa makes some pretty nice tips.
The tru-trak you want should be available soon.
Old Dec 28, 2008 | 01:24 PM
  #1524
Stephen's Avatar
Car: 87 GTA
Niel....You aren't running rear lower control arm relocation brackets?
Old Dec 29, 2008 | 10:20 AM
  #1525
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
I will be. I actually have them at home, so when I get the car back i'll put them on.
No, I don't know anyone with the big magazines. That would be great if you could introduce your connections to this thread and see what they think.
Thanks!
Old Dec 29, 2008 | 11:39 AM
  #1526
Car: Jeep
Engine: small
Axle/Gears: rear
The Muffler is not equal side to side to offset the drivers weight in the car....
Old Dec 29, 2008 | 04:43 PM
  #1527
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
What kind of k member was that before it was modified?
The car is looking great.
Kory
Old Dec 29, 2008 | 09:19 PM
  #1528
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
huh?
Old Jan 1, 2009 | 01:12 PM
  #1529
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Kory
The K-member is from BMR.
huh?
LOL, he was joking.
Happy New Year everyone!!!
Old Jan 1, 2009 | 03:56 PM
  #1530
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
I almost forgot, here are pics of the rear coilovers installed. They are the QA1 double adjustable coilovers.
Just so you guys know, I do plan on cleaning up the rear end housing & cover (will probably use POR-15 on it), will replace the sway bar end links (bushings are shot), powdercoat the LCAs silver as well as the sway bars (front and rear) to match the recently powdercoated panhard bars. Also, will install the LCA relocation brackets (weld in).
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3138910863_2d1c8c921b_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3138912649_d888d49df6_b.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-3139741248_541da723c0_b.jpg
Old Jan 1, 2009 | 04:35 PM
  #1531
Demon355's Avatar
This car of yours is going to be the ultimate 3rdgen, you know that right? Awesome build! Keep the mods and pics coming!
Old Jan 1, 2009 | 05:13 PM
  #1532
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Just got me the same coil overs installed as well
Nice job Neil, I am excited to start a thread on my build in 3-4 weeks but it will be too hard to out do you but I will try
Old Jan 1, 2009 | 06:23 PM
  #1533
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
amazing job.. diggin the dual exhaust set up
Old Jan 4, 2009 | 12:48 PM
  #1534
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
So is this the most invested (time and money) Third Gen here?
Old Jan 4, 2009 | 02:47 PM
  #1535
19911LECAMARO's Avatar
Car: 1991 1LE CAMARO
Engine: 383 TPI W/NOS Fogger Kit
Transmission: WC T-5
I know you hear it all the time, but WOW, great job!!!
Old Jan 5, 2009 | 08:55 PM
  #1536
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
where in the hell is there a video of this beast!?!?!?!
Old Jan 6, 2009 | 08:51 PM
  #1537
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
yea... good point!!
can we get someone to film a video of this!!!!
Old Jan 7, 2009 | 08:54 PM
  #1538
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Neil, you may remember me from such posts as....
Really... she is beautiful, is she available for a date on a friday night? I'll serve a drink of her choice, 103+, or perhaps some home brewn 93 and nitro methanol? I know, a car can dream right? She deserves the best. ha before you know it your car will have stalkers and you'll be chasing after guys, and girls that are caught in local parking lots dry humping the hood of that beast on 4 wheels. Dont be surprised when the 83 year old man on the corner goes 'oh my goodness' when you light the tires up one time, and he jumps on the hood!
Still impressed by your craftsmanship, can hardly wait to see the videos of the first 'roll out of the shop' experience! I know...
Old Jan 7, 2009 | 09:14 PM
  #1539
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
ok i hate to be one of these guys that ask questions that have prolly been answer'd but did we ever get an intake for the car? ive been dyin to see it.
Old Jan 11, 2009 | 05:28 PM
  #1540
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Thanks and your car is lookin' pretty bad a$$!!!
Originally Posted by IROCZman15
yea... good point!!
Well, I don't have a video camera yet. I was going to wait until just before I fire the engine up to buy one. So, in the next couple of months i'll put some video's up
Old Jan 11, 2009 | 05:37 PM
  #1541
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Dude, that was too funny! Well, I actually got the car back from the fab shop yesterday and got her cleaned up and will start flaring the brake lines this week! Anyone know if it's possible to powder coat the brake booster without messing up the internal components. If so, give me your opinion, should I powder coat it a satin black or silver (same silver on the panhard bars)? The master cylinder is polished billet aluminum, so what do you think?
No, I haven't ordered the intake yet....it will be a Hogan intake with a Ford GT throttle body . I should have it ordered by the end of the week and i'll update you guys as to when I should receive it.
Old Jan 11, 2009 | 06:20 PM
  #1542
heff17's Avatar
Car: 89 Camaro
I loved the look of his single carb intake so i took a look at his price list. Am i reading this rite at $2,xxx?
Old Jan 11, 2009 | 06:26 PM
  #1543
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Yep.... Some sheet metal intakes are upto $3,xxx.
Old Jan 19, 2009 | 07:04 PM
  #1544
lotusstunts's Avatar
Car: 1989 IROC-Z
Engine: 406
Axle/Gears: 9 bolt 2.77s
Update!!!
Old Jan 20, 2009 | 12:14 AM
  #1545
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
so i saw this thread on the "new posts" section. that was at 7:04 pm. its 12:12 AM now. HOLY CRAP! i havent read this much since high school. crazy crazy crazy. unfortunately when i started reading i actually expected this to be done. dissapointed but i know good things come in time
but seriously though.. please finish quickly
lol good luck Neil, hope things kinda turn around for you and you have TIME to work. ill keep waitin for updates
Old Jan 20, 2009 | 09:33 AM
  #1546
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
that exhaust is sweet.
i love the the rear view exhaust shot.
thats all people will be seeing of this car any way, so it should look good i guess.
do you have a full exhaust shot yet?
from underneath
sweet car
Old Jan 25, 2009 | 08:47 PM
  #1547
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
I finally made a little progress this weekend. First, I made some wood blocks from 2x12's in order to get the car high enough off the ground (with the suspension comressed) so I could properly measure for the driveshaft which I will order from Denny's Driveshafts tomorrow a.m. Also measured for the intake manifold and I will order that tomorrow as well......I am hoping to make some faster progress now! Oh, also installed the wiper motor and included a few more pics of the new headers.
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-brake-sys-001.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-brake-sys-005.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-brake-sys-006.jpg
Old Jan 25, 2009 | 08:52 PM
  #1548
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Here are pics of the SSBC billet master cylinder installed (not primed with fluid yet). This week and into the weekend I will begin routing the brake line and flaring. I have been saying this to friends for weeks, but I will defintitely be worlking on it!
Attached Thumbnails Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-brake-sys-014.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-brake-sys-011.jpg   Phase I done, Phase II-interior almost done, and now Phase III-drivetrain (454 LSX!)-brake-sys-016.jpg
Old Jan 25, 2009 | 08:56 PM
  #1549
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
from underneath
sweet car
Thanks! But, I will be "tweaking" the exhaust tips once the car is alive. The tips currently are too long for my liking.
I will take a full exhaust shot and post in a dew days.
  #1550
Ca[maro]88's Avatar
thats lookin good. i realllllly wanna see it done lol. how much work do you have left and when do you think youll get it finished?
