SS hood won't open on its own
Old Sep 9, 2006 | 08:41 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
ever since i installed my ss hood i can't just pull the cable and have it open.. it takes 2 people to get it open and even then it's a pain in the ss....any suggestions..?
Old Sep 9, 2006 | 09:09 AM
Fastcamaro87's Avatar
try adjusting the rubber bumpers on the rad support.
Did you install the hood spring?
Old Sep 9, 2006 | 09:22 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Mine is like that too. Be sure to have the spring installed and to lube the lock mechanism well. That has worked pretty good so far. Some times when it has been sitting for a while it still takes a little tinkering. A light push on the hood right above the lock usually does the trick then.
Ken
Old Sep 9, 2006 | 09:29 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
If you have the spring in there it should just pop right up like stock. Mine does...it probably just needs to adjusted. Somethings binding up.
Old Sep 9, 2006 | 09:53 AM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
hmmmm
i do have the spring installed.. should i go up with the bumpers or down.. or should i remove the latch and bumpers and just add hood pins...?
Old Sep 9, 2006 | 10:12 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
I wouldnt use the bumpers to put pressure on the hood. There just for support. Its just binding at the latch somewhere. If it was mine i wouldnt put pins on it either. dont remove the latch you need it.
The latch has two bolts that lets you adjust it up/down and side to side. Loosen those and move it around till there is no binding. Can you feel pressure from the spring when you push the hood down? Might need a new one. Or take that one off and pull it out till its a little taller.
If its adjusted right you should be able to keep all the factory bumpers. There what keeps it from moving around at speed. Just like stock.
Old Sep 9, 2006 | 10:21 AM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
well,,,,,
i'll try pulln the spring and adjusting the bumpers all the way down. i guess....the latch pulls freely....its right outside i'll go try that...
Old Sep 9, 2006 | 10:30 AM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
well the latch moves freely and i put the bumpers all the way down, tried to stretch the spring and i closed it, and it wont open,hmm i'll have to play some more......
Old Sep 9, 2006 | 10:05 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I ended up using locking hood pins. The stock spring was too heavy and would actually push the hood up causing a gap on the left side.
Old Sep 10, 2006 | 06:52 AM
91RedBigFinZ's Avatar
This may sound obvious, but this was happening to my car's stock hood when I bought it. Thie guy I bought it from would 'just hit it' and the hood would pop up after pulling the release
I just used some WD-40 to lube up everything I could (cable, hinges, etc.) and it has worked fine ever since.
Doug
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
