Help with Outer Window Trim!
Old Sep 13, 2006 | 01:00 PM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
I need to replace the black trim piece that runs along the outside of the windows on both doors. Does anyone know if Classic Industries carries this piece?
Thanks,
Joe
Old Sep 13, 2006 | 01:20 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Anybody who carries weatherstripping will carry it. Classic Industries, Year One, Hawks, 1AAuto and dozens of others all have it. On ebay you can still find new GM ones, which means that Midwest Muscle and TPIparts.net might have them too.
Old Sep 13, 2006 | 01:33 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
What are the steps for installing one ? I think someone said its possible without taking the door panels off. whats the best way to get this done. mine need them bad.
Old Sep 13, 2006 | 05:18 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
it is impossible to remove those with the door pannels on. i did mine when i painted my car, theyre kinda a bitch. i got mine new from GM, think they were 98 for both. anyway, remove the door pannel, remove the mirror, unbolt and move the triangle by the mirror, then theres like 12(i think) 7mm screws to get out. i used a wrench cause its tight. i also removed the window stops so i could pull the window outa the way a lil, makes it easier. some of the holes on my new GM ones didnt line up with the holes in the door, i had to drill new ones. theyre a bitch to do but def worth it once its done.
matt
Old Sep 13, 2006 | 06:59 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I bought mine at the dealership, a little over 50 bux
You have to remove the door panel
loosen the felt window guides
remove the black triangle piece
Old Sep 13, 2006 | 09:08 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Check out this thread:
https://www.thirdgen.org/forums/body...+felt+shortcut
PITA job, but well worth it. Your inside door bottoms and maybe even the backs of your door panels will thank you for keeping water and debris out of the door cavity.
Old Sep 14, 2006 | 05:47 AM
Car: 84 Trans Am
Engine: V8 305 4bbl
To those who have a Classic Industries magazine:
Is it part #G7962 and G7963? (on page 249 of the F2007 catalog).
Thanks,
Joe
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
