What are these pieces called?!?
Old Sep 27, 2006 | 07:56 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
They are the metal retainers that go along the window side of the two pillars on my T Top car. There are two per side. They screw to the body, and the weatherstripping is glued inside of them. I'm looking at buying a new set but I do not know what they are called. Can anybody help me out?
Old Sep 27, 2006 | 08:59 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I don't know what the technical name for them is. What is wrong with yours? They aren't the kind of part that wears very much.
If you need the GM part number, I can probably get them for you, just let me know.
Old Sep 27, 2006 | 09:10 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Portions are somewhat bent up and tweaked. I suppose I could reuse them, I just wanted to compare the price of new ones to the time and effort involved in cleaning and reusing my old.
Old Sep 27, 2006 | 09:18 PM
Bull's Avatar
Engine: LT1; None
All those things do is hold the rubber in place...unless they are really tweaked, I'd reuse them.
But I'll check my parts book to see if I can find the part numbers for you. With that, you can check your dealer or gmpartsdirect.com for prices and availability.
Old Sep 27, 2006 | 09:53 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Well I guess they arent too bad. I'm having a hell of a time getting the old weatherstripping off them. Its hardened and is just a real pain. Any magikal substance that dissolves the adhesive they used at the factory?
Old Sep 27, 2006 | 10:19 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Try acetone, turpentine, MEK. If those don't work (or you can't find them), try Naptha (petroleum ether), gasoline, denatured alcohol, Xylene (Xylol), or Toluene (Toluol)
Old Oct 2, 2006 | 11:46 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Any word on the GM part number? That would be great if you could get that for me, I would really appreciate it.
Old Oct 3, 2006 | 12:40 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Not sure what you are looking for is listed w/in but, check my sig..
Old Oct 5, 2006 | 11:18 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
There is some soft foam time stuff on the backs of these, the part that contacts the body. Will I be OK stripping this stuff off and then gluing the retainer, metal-on-metal to the body? Or should I apply the glue to the foamy stuff?
abray1
Sep 14, 2015 08:18 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
ericjon262
Sep 11, 2015 06:07 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
